Plumbing Logo
J
James Martin Posted on Oct 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shower drips unless forced really hard. this is 1961 vintage kohler shower faucet.
Bill Johnson
Level 2:
  • Expert 306 Answers
  • Posted on Oct 22, 2013
Bill Johnson
Expert
Level 2:
Answers
306
Questions
0
Helped
183605
Points
673
Hello James, You might want to try changing the washer on the end of the stem. Try using a beveled washer instead of a flat washer. You might not have to turn the knob so hard to turn it off. Good luck hope this helps.
4 Related Answers
Anonymous
  • 68 Answers
  • Posted on Dec 31, 2008
SOURCE: Pressure problem with Kohler shower faucet??
Hi pglaw,
My best guess is the supply valve for the hot side isn't open all the way. This valve is right on the valve and is accessed by taking off the front cover plate. This would still allow the pressure balancing valve to let water through but then you would have a small flow on the hot side.
If this isn't it then then cartridge is bad.
Please rate this response and good Luck,, phil
Anonymous
  • 195 Answers
  • Posted on Mar 16, 2009
SOURCE: kohler bath/shower diverter stem stuck on shower
Probably has water deposit minerals build up on it. Push and or pull with pliers until freely moves,soak in Lime away solvent ,toothbrush on.
Anonymous
  • 3600 Answers
  • Posted on Sep 27, 2009
SOURCE: Kohler Fairfax shower faucet repair
You will need to buy the o-rings to fix it. You can buy at most hardware stores if you know how to turn off the water you can fix this with more instructions. Let me know if you need more help.
Anonymous
  • 10 Answers
  • Posted on Oct 24, 2009
SOURCE: No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
2answers
My Kohler shower faucet is dripping after I shut the water off, my house was built in the 1980's!
All faucets do this, and 30ish years is OUTSTANDING performance. Eventually, the seals wear and fail. Just replace them...
Jul 08, 2011 • Home
One shower head inn 3head automatic system does not spray, just drips.
there could be dirt in the shower head or the two way divertor valve. i would remove the shower head first.
1helpful
Hi, my shower faucet /head drips regularly how to repair the leak?
You need to order seals and replace them. Typically, dirt in the water system damages the rubber (neoprene, plastic) soft parts. Sometimes the damage wrecks metal parts, but this is less common.
1helpful
On new Moen shower faucet, when I turn on faucet, water drips from shower also.
The faucet was installed upside down.
The shower riser pipe in the wall is to short( the distance between the faucet and shower head).
One of the biggest problems is if your shower faucet was installed with Pex pipe to the tub spout. Pex pipe will restrict the flow and force the water back up and out of the shower head.
The tub spout must be piped with at least 1/2 brass pipe nipples and fittings, or 5/8 OD. copper pipe and fittings.
Hope this helps, if you further questions please let us know.
Leaking shower head
Not unless you had a backward plumber , If the diverter at the faucet is open for tub, then no water will go up the shower, The shower may hold enough water up there to make it look like a drip, Even if the valve was leaking all the time, it would not go up, it would come out the faucet. It only works with pressure. Unless the valve was plumbed wrong,,, Hope this helps.
1helpful
Replaced shower valve. still drips from tub spout
The cartridge has 2 or 3 o-ring type seals around it that feed the water through, it picks up both hot and cold and mixes them. Some cartridges are replaced as one, some you have to replace the seals, just take the faucet info to the hardware store and match it up. I think the diverter is for the shower. It sends the water up instead of out.
Been using shower for a couple of years .when fifished showering it will not shut water off all the way felt like stem was stuck not going back to close of water supply.After forcing it back all the way it...
First determind what side is dripping(hot/cold) then turn off water to entire house unless you have separate shutoff for shower behind wall. take a screw driver remove handle then use channel lock pliers to remove stem on the bottom side of the stem there will be a screw with a rubber washer on it you must remove the screw and replace the washer them re assemble Oh go to home depot and buy a the assorted pack of washer for faucets and stems find one that fits the pack cost about 4.99 best to change both rubber seal washer on hot and cold sinc e you have the water off
Faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
Top Kohler Plumbing Experts
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
