20 Most Recent
Kohler K-8803-VS Duostrainer sink basket strainer, Vibrant Stainless Questions & Answers
Where do you find replacement
I contacted the manufacturer. They had the feet at $4.70 per package of four feet. I ordered two packages. I received what they sent today. The shipment included ONE package of feet, A BILL for $4.70, TAX of $.61 and Postage and Handling at $3.99 for a total of $9.30 for four feet. When I checked online the see if there were any other sources, I entered the item number, 84544-0. and found PLUMBERSURPLUS.COM. They had the same feet at $3.22 per package of four; NO tax and FREE shipping. I ordered two packages for a total cost of $6.44.So my Solution is to bypass Kohler,, which is a bit on the greedy side, and buy these feet directly from PLUMBER SURPLUS or whatever online site offers the best deal. I would continue to use Kohler to get part numbers as needed but, unless you're into philanthropy for large corporations, do not buy from Kohler. Best of luck.
I need to find replacement
Call Kohler Plumbing customer service: 1.800.456.4537, choose option 2 for service parts.Tell them you need a "Feet Replacement Kit" for whatever model name/number and color your basement rack is. Prices run about $1 per piece plus shipping.
Rubber feet on stainless steel
Kohler is generally good about standing behind their products. I would get a hold of customer support and they should help you with that.
How do I remove the plastic insert to access the cartridge on a Kohler K-171 kitchen faucet?
To remove the plastic insert on your Kohler K-171 kitchen faucet, you can follow these steps:
First, turn off the water supply to the faucet.
Next, remove the handle of the faucet by unscrewing the set screw on the underside of the handle using a hex wrench or an Allen key.
Once the handle is removed, you should see a plastic insert that covers the cartridge. To remove this insert, use a flathead screwdriver to gently pry it off.
Once the plastic insert is removed, you should be able to access the cartridge.
If you need more detailed instructions, you can refer to the installation manual for your Kohler K-171 kitchen faucet .
Valve is set to far into the wall...
First, your not going to like the solution. There really is no way to solve this on kohler faucets. Some companies make adapters but as far as I know kohler isn't one of them. Hopefully you can cut a hole in the drywall behind and put it where it should be, if not the marble comes back off.
