2000 Dodge Dakota Quad Cab Logo
R
Ryan Frenzel Posted on Oct 25, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2000 dodge Dakota with the 5.9 v8 my ecu was not reading to my obd2 scanner so I replaced the ecu now that I have done that it sill wont start my fuel pump is priming and my spark plugs are wet I have spark on cylinders 1 and 3 but no spark to 2 and 4 I just replaced my cap rotor and pick up coil any ideas on what could cause this?
jack layton
Level 3:
  • Dodge Master 5,569 Answers
  • Posted on Oct 25, 2017
jack layton
Dodge Master
Level 3:
Answers
5569
Questions
0
Helped
2398084
Points
20059
What about spark plugs and plug wires on those two cylinders with no spark? This is a v8 engine, you didn't mention the other cylinders? The rotor turns when you crank it?
5 Related Answers
Anonymous
  • Posted on Sep 05, 2008
SOURCE: 1995 Dodge Dakota Pick up
go to Didgeforums.com.
I had a similiar problem, found the solution there. It was the wiring harnes on the drivers side under the hood, just above the wheel well. there are a cluster of wires in a bundle. I unpacked the bundle carefuly and sure enough the were two or three wires all coroded, had wite powder from corosion. repaired the connections and bingo. I posted details at dodgeforums.com. browse around there. I posted pictures as well. this is a common problem.
dennymulford
Dennis Mulford
  • 1055 Answers
  • Posted on Mar 20, 2009
SOURCE: 86 dodge 250 v8-318 no fire at spark plug, will not start
did you change the main coil and coil wire?if so then check the ing resistor and then the computor box
Anonymous
  • 7 Answers
  • Posted on May 26, 2009
SOURCE: 1997 Dodge Ram 1500 5.2 liter won't start
I WOULD SAY IT IS THE COMPUTER {BRAIN} THAT IS WHAT SENDS THE FIREING ORDER AND VOLTAGE AND SETS THE TIMEING SPECK I WOULD SAY CHECK THE COMP
Timpala
  • 7 Answers
  • Posted on Jun 17, 2009
SOURCE: slow start 2004 dodge dakota v8
P0038 typically indicates O2 sensor failure or possible grounding out if the cabling to it has failed. Start with that as it is easier to replace than all the plugs/coils etc. Reset the code and cross your fingers.
Anonymous
  • 31 Answers
  • Posted on Aug 24, 2009
SOURCE: 1995 dodge dakota 2wd 3.9 no spark to plugs,or coil,orfuelpump
First of all let's explain how the spark gets to the plugs. There is a crankshaft position sensor and a cam sensor. They are what determines when to fire the coils and injectors. The crank sensor is located on the passenger side on top of the bellhousing, the cam sensor is the pickup plate in the distributor. As the engin turns the send refernece pulses to the computer which grounds and ungrounds the ignition coil causing it to discharge and send voltager from the secondary coil wire to the center tower in the distributor cap. The rotor button recieves the voltage and distributes it to the 6 towers (1 for each cylinder) If you say you're getting spark from the rotor that tells me the primary side of the ignition system is working, and the secondary side is working into the distributor cap. I'd check for spark out of the plug wires at the plugs. Pull a wire and insert a #2 phillips screwdriver into it, hol the shaft of the screwdriver aprox 1/8"(no more) from the exaust manifold and observe the spark as someone turns over the engine. You should see a nice blue spark. If theres spark, spray a little gum cutter in the throttle body an crank it, if it fires you have a fuel problem. Install a fuel pressure gauge on the schrader valve on the fuel rail and observe it as you crank it. If theres no fuel pressure maks sure there's fuel in the tank, if so climb underneath and beat on the bottom of the tank with a rubber hammer, the pump may be going bad, sometimes you can jar them and make them run.
2answers
2005 Dodge Dakota SLT V8: Why is the coolant reservoir always appear to be bone dry?
It should never be bone dry. The coolant should be topped up to be between the marks. Did you read the Owner Manual?
https://www.manualslib.com/manual/40540/Dodge-2005-Dakota.html?page=315#manual
91 Dodge Dakota V8 5.2 idles rough and loses oil pressure when braking
Oil sensor is faulty, have a look at the link below
https://www.youtube.com/watch?v=Rwjwl-TzTAA&pp=ygVGOTEgRG9kZ2UgRGFrb3RhIFY4IDUuMiBpZGxlcyByb3VnaCBhbmQgbG9zZXMgb2lsIHByZXNzdXJlIHdoZW4gYnJha2luZw%3D%3D
1helpful
Trying to find a OBD l scanner for a 95 dodge Dakota for under a $100.00, or can I use a OBD ll scanner with an OBD l adapter and achieve the ability to read and clear codes?
An OBD2 scanner can sometimes read an odd OBD1 code but there is no consistency. The OBD2 system is designed to be universal but only as far as faults that can affect exhaust emissions - other faults on the OBD2 system and the OBD1 system are manufacturer/model specific and require either dedicated diagnostic equipment or some very comprehensive software.
1helpful
Have a 98 ram with 318, body smashed. Will the motor transplant into a 2000 Dakota 4.9. Thank u
Greg, you may have to transfer everything from donor truck to make the swap work tranny , computers, wire harness, fuse/relay center etc. Check the attached links,forum for Dakota engine swaps,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
engine swap 4 7 to 5 2 or 5 9 Dodge Dakota Forum Custom Dakota Truck Forums
2000 dakota engine swap not sure which engine would be easier 4 7 or 5 2
http://www.dodgedakota.net/boards/v8/12324.html
318 Dodge dakota 0 60 v8 swap
How do I turn of the check engine light on a 1991 dodge dakota truck with a v8 engine. I've tuned the truck up but the light will not go out.
You have an OBD1 System
Just like the current OBD2 1996 thru 2011,
you have to check for codes,then diagnose
your fault codes
Replaced timing change on a 1992 dodge dakota set the number one piston tdcbut when dialed in its at the #6 position what do i do.
#6 on a V8 is BDC on exhaust stroke.
Don't forget your working on a 4 cycle engine.
1-8-4-3-6-5-7-2
Will start then die.
if it starts runs and dies instantly, the fuel pump could be the culprit, its getting the signal to sqirt fuel to start but then no voltage to continue pressure.. check fuel pump and also worse case senerio is the ECU (main computer could be bad)
2helpful
2answers
Dodge Dakota Battery still wont charge
I was running into this problem with my 97 5.2l Dakota and after some searching I found the the "Fuse Link" between the Alternator and the Battery was blow. Found a suitable "Fuse Link" at a local Auto parts store for about $5.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
