Coffee Makers & Espresso Machines Logo
cele yager Posted on Oct 07, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Keurig leaking from bottom - Coffee Makers & Espresso Machines
Dave Glabb
Level 3:
Master:
  • Master 257 Answers
  • Posted on Dec 18, 2013
Dave Glabb
Master
Level 3:
Master:
Answers
257
Questions
Helped
169578
Points
1085
Check the Upper Rubber Gasket (fits around the top puncture pin). If it missing you will have leakage because here's no seal to protect leakage. You can buy it online or call Keurig Customer Service (if you still have warranty)
OR:
Upper Rubber Gasket not making a seal with the K-Cup or Reusable Filter and the water and/or coffee grounds leak out. To fix it simply move Upper Rubber Gasket 1/4" down. This should close the gap between K-Cup and upper needle.
1helpful
How do I remove then casing from Keurig K10 manufactured in 2014 water leaks from the bottom
I have taken apart a Keurig and most items are not serviceable but remove the screws on the bottom and follow your water lines and see if one came lose or is leaking.
Why is my keurig 560 leaking water from the base
Most likely the water lines inside your unit are leaking. If you can take the bottom of B60 off and look inside the unit. Usually, the line that comes off the water pump is leaking at the T connector. If not leaking there look for other signs of leaking while the bottom is off. You can call Keurig 800 number to see if your unit is still under warrenty. Hope this helps.
My Keurig leaks from the bottom, it's a pain.
You may have water in the holder that supports the CUP. It needs to flushed as it has a limited area for maintain the overflow.
3helpful
My keurig leaks from the bottom only when brewing coffee. Can it be fixed?
Here is a tip that I wrote about Keurigcoffee brewers and the Keurigleaking problems
Keurig OneCup Coffee Brewer leaking
heatman101
Leaking from the bottom of my B70
heatman101
Works but water ( lots) is leaking out the bottom.
heatman101
Coffee maker leaks from the bottom somewhere. Any suggestions?
heatman101
2helpful
3answers
My Keurig Platinum B70 is leaking. When I put the water reservoir on to the coffee maker, water seeps out the bottom where the reservoir sits into...almost like the little valve in the reservoir stays...
My Keurig B60 had the same issue. The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Permanent Keurig filter leaks
Are you using the my k-cup with the Keurig pre-filled K-cups? If so it won't work. There must be a needle on the top and bottom of the K-cup for this machine to work. The My personal K-cup does not have a needle in the bottom. It's only to be used for filling with your own coffee.
Top Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
