20 Most Recent Keurig Elite B40 Coffee Maker Questions & Answers
I pulled the plug cleaned the machine thoroughly and it is back to normal. Right now i'm in contact with Keurig for a replacement part that is broken.
Keurig Elite B40... | Answered on Jan 04, 2019
It's just off. Flick the switch on the back.
Keurig Elite B40... | Answered on Sep 13, 2018
Remove the Kcup basket and clean. Rest and strat over. Pull down and reset handle.
Keurig Elite B40... | Answered on Apr 28, 2018
Perhaps more than one problem people are dealing with but here's what I found. The round float in the tank is magnetic so it's either activating some crappy mechanical switch or more likely a hall effect sensor. Remove the tank and dump the water so the float will rise from the bottom when you refill it. Take a good strong magnet and slide it around the side of the unit where the float would be, tapping it as you go. Put the tank back on and fill it. One try and I was back to making coffee.
Keurig Elite B40... | Answered on Jan 23, 2018
try descaling it sound light its full of scale
Keurig Elite B40... | Answered on Dec 17, 2017
return it to Keurig as defective . it should never short out the outlet
Keurig Elite B40... | Answered on Oct 15, 2017
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Keurig Elite B40... | Answered on Oct 11, 2017
7 years is a reasonably good life for a coffee maker but if small works ok then drink 2 cups LOL
Keurig Elite B40... | Answered on Sep 23, 2017
I have had this same problem when all of some of the coffee is ground too fine. It needs to be the correct particle size and if it is too fine, it will clog the screen and either overflow or not flow at all. Look at the ground coffee you use and check to see if it is uniform size or there are a lot of very fine grounds mixed with the coarser sizing. Try asking a coffee shop to grind you some coffee specifically for your Keurig cassettes. Most pre-grounds drip coffees are too coarse and many grinders in the stores where you grind your own whole beans do not produce a uniform size. I have an OEM Keurig cassettee and two generic cassettes and the screens have different pore sizes, with the Keurig being finer.
Keurig Elite B40... | Answered on Sep 09, 2017
We live in an area with rather mineralized water. and have had regular issues with this. the best solution we ever had to this sort of problem was to simply descale with a vinegar mix until it ran clean and then go with very regular descaling 9 in our case 2 a week, unitl the dog chewed through the cable). I had my B40 for almost 3 years. Good luck!
Keurig Elite B40... | Answered on May 12, 2017
Circuit board is failing, replace or junk system.
Keurig Elite B40... | Answered on Apr 07, 2017
Keurig Elite B40 Coffee Maker Logo
1,057 questions posted
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Pierre Laplante
Steve Allison
Steve Allison
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Keurig Coffee Makers & Espresso...
  • Keurig Coffee Makers & Espresso...
Most Popular Question
keurig says auto off set need turn
  • Coffee Makers & Espresso Machines
