20 Most Recent Keurig B70 Coffee Maker Questions & Answers
Sounds like it is time to descale
Keurig B70... | Answered on Apr 29, 2019
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Keurig B70... | Answered on Jan 02, 2019
Here is a tip that I wrote that goes into detail about how to descale yourKeurig Coffee Brewer
How toDescale your Keurig Coffee Brewer
heatman101
Keurig B70... | Answered on Nov 07, 2017
Buy a new one, likely over heating inside
Keurig B70... | Answered on Aug 09, 2017
It all depends on the size cup or mug You use
Keurig B70... | Answered on Apr 08, 2017
heatman101
Keurig B70... | Answered on Feb 15, 2017
Check the needle in the top, it might be plugged up with grounds
Keurig B70... | Answered on Sep 02, 2016
Scale---or mineral deposits---form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water
1.Unplug the coffee machine and remove the cup.
2.Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
3.Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
4.Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
5.Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
6.Unplug the machine and dump the water into the sink.
7.Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue
Keurig B70... | Answered on Jun 30, 2016
I would not do this. It may damage the internal hose material. I recommend using Keurig's method for cleaning: run 3 cups of white vinegar through it, let it stand 4-3 hours (or longer) then rinse it well by running several tanks of water through it. That will remove all hard water residue within the unit. Also clean out the needles that pierce the cup, top and bottom, with a paper clip, since they often have coffee grounds plugging them.
Keurig B70... | Answered on Nov 17, 2015
Keurig B70 Coffee Maker Logo
597 questions posted
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Pierre Laplante
Steve Allison
Steve Allison
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Keurig Coffee Makers & Espresso...
  • Keurig Coffee Makers & Espresso...
Most Popular Question
keurig says brewing not brewing
  • Coffee Makers & Espresso Machines
