When water leaks from the dispenser like this it will be caused by a defective water control valve that will not shut properly when off. The leaking water is the same as a leaking faucet. The KSCS25IN uses a=> W10247725-Water Control Valve or HERE
Sea Breeze
SOURCE: water is dripping from my water dispenser and I can't stop it
usually it leaks becasue of air trapped in the line, did you just replace the filter ?? or oso to a new installation??? if so try holding the button in for a few min( a large picher full) to clear any trapped air in the line
SOURCE: water dispenser is dripping water when not in use.
replace the water valve its not shuting off completly . things do go bad . this is a dual valve and controls both foutain and ice maker .. mm
It's not the filter, so it may be the Water Inlet Valve. I assume that the Water Dispense Arm (Actuator) controls the water flow via the Water Inlet Valve. Should I assume the Actuator is fine and just replace the Inlet Valve?
