20 Most Recent KitchenAid (KSRD22FKST) Side by Side Refrigerator Questions & Answers
How to remove the evaporator tray from kitchen aid
I don't know for sure but you may be able to watch a video on how to on YouTube and get a solution to your problem I hope this helps
1/6/2018 2:41:41 PM • KitchenAid... • Answered on Jan 06, 2018
Kitchenaid side by side freezes food in the refrigerator side
The damper between fridge and freezer is most likely stuck open.
10/2/2017 4:01:32 AM • KitchenAid... • Answered on Oct 02, 2017
KitchenAid Superba KSRA25F - makes ice fine - dispensing motor not working
Hello! Please check the "Troubleshooting" part of the manual, especially the part "The water dispenser will not operate properly" Hope it will help! https://manualsbrain.com/en/manuals/1409170/?page=23
8/31/2017 8:31:36 AM • KitchenAid... • Answered on Aug 31, 2017
2answers
Water line to ice maker in KitchenAid Side x Side freezes
Try insulating the water line and moving it away from whatever is causing it to freeze.
8/23/2017 10:23:06 PM • KitchenAid... • Answered on Aug 23, 2017
Electricity to the fridge but no power to fan and compressor is burning hot
with no fan the compressor will overheat.Probably a bad thermostat or fen motor.
8/2/2017 11:29:12 PM • KitchenAid... • Answered on Aug 02, 2017
0answers
I have a side by side Kitchenaide Model ksrv22, It...
Leaking refrigerant
6/17/2017 2:39:39 AM • KitchenAid... • Answered on Jun 17, 2017
Kitchenaid side by side model #DS 110022-RN
Either you have a defrost problem blocking airflow to the fresh food section or you have a blockage in the vent. You're going to have to unplug the refrigerator look in the back of the freezer and see if there's ice build-up on the rear wall of the freezer. Try again with that model number I do not believe that is the correct model number it should have Mod: before the model number. Appliance 911 Sea Breeze if your refrigerator has an additional cooling Zone in the fresh food compartment you may have a damper that is stuck open but I'm going to have to have the correct model number to help you
9/10/2016 5:13:57 PM • KitchenAid... • Answered on Sep 10, 2016
0answers
Can't remove ice storage bin from Kitchenaid side by side
This units are prone to do this. Best way for me to tell you is to work ice bucket side to side. Then shut the freezer door and switch between the cube and crushed ice. Tap the dispenser lever just long enough to engage motor. Basically you are rocking the coupling back and fourth in the auger assembly. Will come loose but may take a bit.
2/5/2016 5:25:45 PM • KitchenAid... • Answered on Feb 05, 2016
2answers
Kitchenaid refrigerator / freezer knocking noise
Hmmm. Makes sure it is not the fan inside the freezer. The compressor is not capable of loud noise since it is sealed and sits on rubber mount. The knocking might be due to the fan blade hitting ice build up. You should not see any frost in a freezer. If there is frost, you can defrost completely then set the fridge to a lower setting.
9/8/2015 2:37:19 PM • KitchenAid... • Answered on Sep 08, 2015
I have a kitchenaid side by side
e9add14b-8293-4e90-ba9a-c3496b147c53.jpgAre you interested in doing this yourself? When you say the Electronic Gemini are you referring to the=> W10219463 Main Control Board I am here if you would like my assistance, Sea Breeze
5/27/2015 8:35:45 AM • KitchenAid... • Answered on May 27, 2015
0answers
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
446 questions posted
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Refrigerators
Most Popular Question
freezer not getting cold dripping water
  • Refrigerators
