Life Fitness LifeFitness 9500HR Treadmill Walking Belt Logo
Phil Posted on Sep 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bad Controller Comm Error. I swapped out Controller but still get same error, any suggestions?
ernesto cuadra
Level 3:
Top Expert:
  • Life Fitness Master 12,223 Answers
  • Posted on Sep 24, 2013
ernesto cuadra
Life Fitness Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4081501
Points
34431
I recommend to replace the control board. This is very critical matter for the electronic machine. see the diagram attached, How the controller motor hast the 80 of control of machine.
go to www.fitnessrepairparts.com and get it
God bless youBad Controller Comm Error. I swapped out - 0ec27df4-0032-4849-b0bd-931ae61aec28.gif
  • 2 more comments
  • Phil Sep 24, 2013
    Hello Ernesto, thank you for fast response. Are you talking about replacing the Controller, which is about 900 dollars. I took the whole Controller from another working unit and it still gave me same Bad Controller Comm error message. Thank you for your patience
  • ernesto cuadra
    ernesto cuadra Sep 25, 2013
    Reset the treadmill. Adjust the REED swtich +S.sensor see the picture attached. Tight and clean the ribbon cable for display++tight and clean the upper and lower connector for control and try again..Reset with the small switch attached to the side power button with small pencil eraser and make click. God bless you
  • ernesto cuadra
    I can not attached the picture. however see your owner manual, or download free from www.fitness.manualsonline.com and see it.
  • ernesto cuadra
    LUBE the deck bel too, with silicones or wax depend of your model machine. God bless you
2 Related Answers
Anonymous
  • 83 Answers
  • Posted on Mar 24, 2010
SOURCE: error message notify maintennce motor
Every time I have gotten this message, I have had to replace the motor controller.
Anonymous
  • Posted on Mar 01, 2011
SOURCE: notify maintenance motor controller comm
I own a gym and have 5 9500's...unfortunately it sounds like it the motor controller board which is around $800. National gym supply or sprotsmith has the part.
We have Lifefitness 9500HR Treadmill. I am getting a Bad Controller Error. We have two 9500HR models. I swapped out Controller, with working 9500HR and still get Error. Keeps going into Notify Maintenance....
I would suggest swapping the consoles to see if the problem follows. If this does not help you figure it out, you are more than likely looking at a wiring issue.
X945e 980.03 service finisher comm - how to fix the issue
The 980.03 communications error on Lexmark X945e indicates a communication problem with the Finisher Controller Card. This usually requires a service call as it deals with cable connections from the finisher, from the bridge unit, the finisher controller card assembly, or the engine card assembly. But try to unplug the printer from power source, replug after 30 seconds. Plug printer straight to power outlet in the wall. Bypass any surge device, power strips or uninterruptible power supply (UPS). These can cause false error messages. If problem continues, I strongly suggest you contact Lexmark technical support or your authorized service provider for assistance. Thanks.
Error message notify maintennce motor controller comm bad
7helpful
2answers
HP 3050 Engine Comm error
I have a HP 3050 three in one and I keep getting a engine comm error
Incoming Fax Error
Maybe depends on poor phone connection from this sender, caused by bad line or a transmitt problems. In faxsettings All fax, change "error correction" to off and "V34" faxspeed to slow, this will help.
ERROR MESSAGES
nthemba- all the error codes you see indicates phone line condition or error at reciving fax's end. For more details you can refer to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&lc=en&dlc=en&cc=us&product=79477&rule=17804&lang=en
Comm error
could be down to the line, had a similar issue which I believed to be hardware related, so got supplier to send a new fax out, spoke to someone at canon who said is def hardware related, any yet it turned out to be rabbits outside chewed through a cable (was in scotland..) so was a BT issue.
1helpful
2answers
Service Error
58.04 error is a processor error. check to make sure the transfer kit is installed correctly. Take it out and put it back in even if it looks like its in good.
If that doesn't work, take it to a service technician. It will probably have something to do with the connector from the Low Voltage Power Supply to the DC Controller, bad power supply or bad DC Controller.
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
