20 Most Recent
HP LaserJet 5200tn Printer Questions & Answers
13.02.00 paper jam in HP 5200
The 13.02 error message indicates that paper did not clear the top of page sensor (PS103) within the specified amount of time allotted by the DC Controller. This sensor is located underneath the registration assembly
943 service print head error
sounds like a mirror motor error(this is the laser mirror that spins very fast 20k rpms, you hear the sound when its about to print ,sounds like a jet spinning up). In this case you will need a pro to look at it or replace the machine....
Laser Jet 5200 PRINTER
error
52.00 error is a "scanner motor" problem.
Replace the scanner motor 1st, 2nd replace the DC Controller.
If you are not a printer tech, you will need one.
80.0017 jdi error
If you have tried to upgrade your firmware, the new one cannot cope with the old network jetdirect firmware. You had to upgrade the Jetdirect firmware first. Now, remove the network card and see if the printer goes "Ready". If so, the problem is isolated. Now you have to find a way to update the jetdirect firmware. Probably with another printer or see if the ftp method works even with the error on the printer at this site: https://support.hp.com/bg-en/document/bpj07429
Standard top bin full?
I suggest you remove any sheets of paper from top tray then lift up and release a black plastic flap found under a plastic overhang on paper exit tray. This lever (If its not broken/missing), should be free and should drop down(under its own weight) freely. If not then it will involve using the manual to remove the top cover and find where lever is jamming (usually jumped out of a guide bearing.)
regards
carmike
58.04 error
This is a problem with low voltage power supply being put into a safety shutdown by sensing an excessive load (i.e a short circuit on the output) check all cables for damage to wires where they pass through metal frames. I have heard of a case where wires were "rubbed" and damaged by the main motor due to cable being wrongly routed. if that does not fix then its time to think seriously of a replacement printer
where paper comes out on top, on right hand side is a plastic lever that is normally resting down. If it gets stuck in the up position, or the bin is full it will give you the errorPart number is RC1-7460-000CN, bin full flag
