SOURCE: INSTALL SIDE VIEW MIRROR ON A 1997 TOYOTA CAMRY
Yes, you have to remove the door panel.
Remove the 2 plastic protectors on the front edge, and remove the 2 brass colored screws. Next, remove the push pins from the latch side. Push in, and pull out the whole thing. Next, under the armrest, remove the screw. Lift up the power windoe control, being careful to not break the plastic retainer tab. Remove the screw under the window control. Starting at the bottom, pull out the panel, and, when all of the clips are loose, pull the panel straight up. It is best to do this with the door panel as warm as possible, like in a heated garage. Doing this outside in the cold will break all of the plastic retainer clips; they are quite brittle whn cold.
I hope this helps
Thanks for choosing FIxYa for assistance. A FIxYa rating (4 blue diamonds) would be greatly appreciated.
SOURCE: 1999 camry trunk lid & high mount brake lights all inop...
The jiggle method is not enough you have to look at the wires. I just did and I found out that all six wires were broken close to the splice. That splice is located close to the back seat.
Hope it hepls.
SOURCE: Need instructios to repair 1997 Toyota Camry Broken Exterior Door Handle
Two 10mm bolts, or nuts, hold the handle on from inside the door. dont forget to remove actuating rod from old handle. probably clip is broke also.
SOURCE: power steering belt on 1991 toyota camry
Locate the idler pulley. Loosen the nut in the center of the idler pulley. Then loosen the bolt that protrudes from the back of the pulley. This will let the belt go slack.
SOURCE: sun visor on 2008 Camry broke - on both sides
To be honest, Save your 90.00 and pop it in your self. Sun visors are very easy to change and will take you all of 5 minutes. Most visors are held in place by 2-3 little screws that you will see at the base of the visor and looks like they are screwed into your roof. just take the screws out and the visor will pop right out for you. then just do the opposite to install it. It really is that easy.
Good Luck and I hope this helps.
Twitter, SwiftAuto
swiftautorepairs.com
