SOURCE: One piece toilet needs a new gasket. How do I replace it?
The top of the pipe above the flush valve is threaded. Unscrew it, and you will be able to remove the flush valve and replace the gasket.
SOURCE: My K3489 toilet leaks down
Hello, W/D here.
With the water off, drain the tank (lift the flapper). Look inside where the flapper seats. If the (usually black) gasket is rippled, this may be the cause of your trouble. You can remove the rippled portion of the gasket with a razor knife, just be very careful not to damage the flapper seat. Removing the protruding material will allow the flapper to fully seat without damaging the gasket integrity.
Best regards,
--W/D--
