Nikon DSLR D90   Digital Camera Logo
Georgi Grozev Posted on Sep 14, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi... I am having a problem i never had before with my D90, after almost 2 years of usage. At some point i turned the focus mode on manual (on the camera), and when i switched it back to automatic it stayed on manual. Anyone has a solution for that without having to go to a FixShop? Because i live pretty far from civilization at the moment. Maybe if take out the M/A switch off the camera? would that help me? I mean, i don't even care if i can't switch it back... as long as it works on Auto... I need it for my job. Please help... Thanks
Bart Pulverman
Level 2:
Guru:
  • Nikon Expert 362 Answers
  • Posted on Jun 01, 2014
Bart Pulverman
Nikon Expert
Level 2:
Guru:
Answers
362
Questions
0
Helped
83822
Points
625
I would not try removing switches or anything else on your camera if you are inexperienced. You can really screw things up big time and then you will have a really big bill for the repair. I would advise you to go on the Nikon USA website and find the nearest factory repair depot and phone them for advice on this matter. You will probably need to send it to them for repair. They usually have about a ten day turn around. I don't know how you use your camera in your work, but if you must have a camera while yours is in for repair, you can rent one from Adaorama.com. They will ship it to you and then you ship it back at the end of the rental. I have been using them for years and they are very reputable.
  • Jeff Marcus Jul 02, 2014
    I know I'm late to the response on this. However, there are two switches that need to be looked at. The first is on the lens that shows M/MA. It should be on MA for auto focus. The other is on the camera front. There is a switch for C/S/M. The C is for continuous auto focus, the S is for single auto focus, and the M if for Manual focus. Be sure it is not on the "M". On single focus, the camera must acquire focus before it will trigger. On C it will trigger without being in focus. On manual it will trigger at whatever focus you have manually set it for.
5 Related Answers
Anonymous
  • Posted on Apr 25, 2008
SOURCE: nikon d40 digital camera
So, before i take my d40 to an authorized tech, should i maybe see if the lense needs to be cleaned then? silly question I know. But i really dont want to waste money on sucha petty problem.
Anonymous
  • Posted on Oct 26, 2007
SOURCE: Nikon 4300 wont turn off
WARNING!!
This CF card cannot be read
Ian Ballard
  • 20 Answers
  • Posted on Apr 05, 2008
SOURCE: The auto focus is not working on my Nikon D50
I assume the AF/M switch on the body is set to AF as well? This has not been mentioned but the D50 has two drive systems for AF.
David E
  • 97 Answers
  • Posted on Sep 05, 2008
SOURCE: nikon d40 autofocus
Dan62, your camera will never be able to focus on objects with no contrast. The manual specifically states this. However, you can put the AF marker over something with some contrast, half press the shutter, so that it will focus, hold the shutter button halfway while you recompose the shot, and then press it all the way.
A note to others using the D40/D40X/D60 that are having problems with autofocus: please remember that this camera will not autofocus with mechanically driven lenses. It will only AF with "AF-S" or "AF-I" lenses.
Anonymous
  • 10865 Answers
  • Posted on Oct 01, 2009
SOURCE: Nikon D90 stuck on manual focus mode.
DEFINITELY return it while it iis under warranty.
Blurry pictures
I don't know how much experienced you are with a digital camera. Don't even know you have any experience with any camera. But the modern camera's are capable of taking sharp pictures, is used right.
But to let the camera do its work correct it should be setup correct and used correct.
Let me explain.
Most camera's have a possibility to make pictures in automatic. (dail on the green camera symbol) But still there is more to do.
Every camera has a point (or more points, that are used to focus the picture. You can use to put that point where you want the picture be in focus. Most of the time that would be the centre of the frame. But the camera can't focus in theoretical a blink of an eye. It needs some time, to find the focus by differences in contrast, or patterns. A DSLR sometimes can focus in less then a tenth of a second. Compact camera's could need up to one second, before they are in focus.
So try to setup the camera to automatic. Place the focus marks (as described on page 6 of the manual. Then press the shutter realise button half and look if the camera can focus. If it can't, release the button and try again. When the pictures is in focus, then you can press the button fully.
On page 33 of the manual, there are different modes of focus. be sure you use the mode you chose in the correct way.
link to the manual I refer to.
Hi... I am having a problem i never had before with my D90, after almost 2 years of usage. At some point i turned the focus mode on manual (on the camera), and when i switched it back to automatic it...
Are you sure the M/A switch on your lense is on A?
Do you use an older AF lens? Among those are lenses, that have been fitted with a A/M switch.
Is the aperture lock on the lense locked.
Just some things to check before you go to a repair store.
2helpful
Hi I bought my canon 1000d on september 2009 and a year later the autofocus doesnt want to work. In the viewfinder on the far right a number 9 has a green dot flashing next to it. Please help!! Ruthven...
The 9 you see is the maximum "burst" which is (pictures made in rapid succession) and is not an issue with your problem at this time the flashing green dot is the in focus confirmation light and it's good that you are seeing this as we will use it to remedy the problem.
Diagram
Manual focus switch
Diagram here
What I want you to do is put the AF-MF switch in the manual mode if it's already in manual mode then that was your problem switch to AF and go take some pictures. If it's in AF mode switch to MF make sure teh camera is on and look through the viewfinder at a subject say 15 feet (4.5 meters) away something that has contrast then turn the manual focus ring on the camera slowly until it appears to your ey that it's coming into focus when it's in focus the green light will come on solid, now you know what you are looking for focus an several different objects at different distances and focus manually. Now switch the lens over to AF (auto focus) and focus on the same thing but let the camera do the focusing What auto focus will not focus on in something with little or no contrast like water clear blue sky a painted wall mirror chrome glass and a few other things.
Here is another diagram to check make sure you are in the correct mode.
Diagram
Now for the focus point in the viewfinder make sure it's in the center position.
To adjust the focus point do this
Once you have the camera set to the center focus point and the correct AF mode (one shot) auto focus should return to your camera. Have fun Robert from London Ontario Canada
1helpful
Hi, I have a issue with the quality of the pictures I've taken recently on my Z2, the pictures a blurry around the edges. The centre of the photo is sharp. Do you have any suggestions please of what to do,...
This is due to settings change
Please switch the focus mode to multi point focus or any other
current setting will be center focus or spot focus that is why only the center is focused and the rest is blurry
Please refer to your fuji manual for instructions on how to change the focus mode
Thanx and i hope this solves your problem
Please dont forget to rate this information
Hi there i have a auto focus problem. i used mt 50D for the first time on saturday, after about 100 shots Err99 appeared, i turned the camera off and took the battery out an the error message never occured...
The camera is having problems with your lens and this is why it goues into the error mode. Try first cleaning the interface contacts on the lens ( see enclosed pic ) . If this does not sort the problem out then the auto focus motor ( or related hardware ) inside the lens will need attention. Also try other lenses to see whether it is only the lens ( I very seldom see this sort of problem cause by the body ; it is always the lens that gives this sort of trouble )db49ae2.jpg
Canon AF Issues
Change from auto focus to manual focus or focus using only one focal square and change the setting to One Shot. You may need to shoot in Manual (M) mode though. Any of the "auto" modes will not let you.
Manual focus points 40D
Try checking C.Fn III, 3: AF point selection method. Yours might still be on option 2.
0: Normal - Works by pressing the AF Point button and then the Multi-controller.
1: Multi-controller direct - Press the multi-controller to directly select an AF point (without first having to press the AF Point button). Pressing the AF button reinstates all AF points for auto AF point selection.
2: Quick Control Dial direct - turn the Quick Control Dial to select AF points. In this mode, AF points will not be displayed on the LCD panel.
Auto focus trouble
Most likely, you have changed the AF point, which only takes effect in the creative modes (Manual, Av, Tv, P, etc)
There should be a button on your camera that has a grid like pattern above it, like
or so. press that, look through the viewfinder, and move the shutter or rear wheel, you should see the different AF points like up in red, and as you turn different ones will light up, and eventually all of them. also, you can look on the screen on top (or back, if its a rebel) and it will show you which ones are selected while in that mode, instead of looking through the viewfinder.
1helpful
4answers
Nikon D80
EXPLANATION.
1. The problem with 18-135 lens is because it make from plastic. Main problem from plastic is it can be reshaped after a few usage. When the shape ran out, the contact point will be defective. When the contact point didnt really touched, the processor cant send signal to lens to do autofocus (the lens focus using the lens motor, not the body). When u set to manual focus, the body doesnt need to instruct the lens to focus.
2. You are focusing something that is to near than the focal point.
SOLUTION.
1.Try cleaning the contact point on the lens. Then mount it back until the F showing up (F= aperture). This solution depend on your luck too. if the gap between to contact is so far, then it might happen back. Usually when u need it badly. haha
2. try to get more distance from your subject. Just keep press the shutter until the camera focus.
CONCLUSION
1.But new lens with metal mounting. It will last and durable.
2.Buy macro lens to close up. normal lens wont focus at short focal point!!~
What is Flex Digital Magnifier?
When using manual focus(MF) and direct manual focus(DMF) mode, Flex Digital magnifier (FDM) can be used to confirm selected flex focus point by enlarging it to 4x. The focus point can be selected after enlarging.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
