Good Morning REDS, thank you for your inquiry!
I understand that your door indicates it is open and
your washer will not operate. Try resetting the unit by either
unplugging it or flipping the household circuit breaker off. Wait approximately
ten minutes and turn on the washer. Select a normal cycle, confirmed the
latched is securely latched and verify if the washer will start. If the washer
will not operate then it possibly have a faulty door lock assembly or a
communication problem with the control board. At this point, it would be
advisable to contact an experienced appliance repair tech to assist further.
SOURCE: FRIGIDAIRE FRONT LOAD WASHER
I too had the same problem, I closed the soap tray and a magnet popped out and got stuck to the door. Same problem with it acting like it was going to start and then beeped. This is where the magnet goes, just stick it back in, its held in with pressure (barely) :)
I took the whole control panel off to locate the magnetic reed switch, then just reverse engineered where the magnet is supposed to go on the soap drawer.
SOURCE: Frigidaire Affinity ATF7000E Front Load
The control is most likely bad. If lights flash on front let me know which ones and how many as it will sometimes tell me what the failure is. Thanks, please leave feedback or contact me again for more info if you need it.
SOURCE: Frigidaire Affinity Door Lock
under 1st yr warr, sure if thats he issue they would cover, it, a clogged drain pump may cause the same problem though , not being able to drain water , the pump would just hum.
Hello chuckthom980 - Typically EBE indicates that there is an issue with the console control. Contact a professional to have the main control board replace.
