Nordic Track NordicTrack Viewpoint 3500 Treadmill Drive Motor Model Number NTL Logo
A
Anonymous Posted on Sep 10, 2013
I have a viewpoint 3500 nordic track and the screen doesnt work. how can i fix it?
Sheena Gause-Lott
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 17, 2015
Sheena Gause-Lott
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
520
Points
Did you get this fixed? I'm having the same trouble now and can't find a solution any where!
1 Related Answer
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Apr 23, 2012
SOURCE: I have a Nordic Track Viewpoint 3000, the display quit working although the incline and speed seem to be working just fine. Anything I could try to fix?
Dear Sir:
Please see the attached diagram for adjusting the reed switch, clean very well, and tigh the connector wires.
sincerely. God bless you
I need BC 887 manual
[DOC]Nordic Track Achiever Manual
188.166.107.131/nordic-track-achiever-manual.doc
... owners manual pro achiever etc ebay , nordic track achiever bc 887 manual ...nordictrack treadmill achiever reviews viewpoints , nordic track skier exercise ...
[DOC]Nordic Track Skier Manual
188.166.107.131/nordic-track-skier-manual.doc
... treadmill manual google sites , ntl nordictrack nordic track c manual sears , nordictrack ntl 1 user manual pdf download , nordic track achiever bc 887 manual ...
achiever bc 887 Treadmills Questions & Answers - Fixya
www.fixya.com > Forum > Tags > achiever bc 887
Treadmills achiever bc 887 questions and answers. Ask your ... Where is the ENTER button? please follow the instr.manual if you do not have it download it from ..
I HAVE A NORDIC TRACK E 3500 WITH AN INCLINE PROBLEM WHERE BY IT DOSEN'T RESPOND TO THE REQUIRED LEVEL .I'VE TRIED TO RESET MANY TIMES WITH NO SUCCESS .IT SEEMS TO CHANGE THE ACTIONS ON...
1)Lube the shaft, gear from elevation motor see the picture
2) adjust the POT a little.
3) see the diagram attached.
4) RUN the software calibration go under the hood motor and see the instructions for troubleshooting, and fix it.
God bless you
Dear Sir:
5helpful
I have a Nordtrack viewpoint 3000, the tv will come on and when I touch the start botton it just beeps.
I had the same problem with my Nordic track. I pressed every button until I found the one that did not beep. The one that does not beep is stuck. My problem was with the Ifit button. The first few times I would push the bad button until it started beeping. That worked for awhile (couple of weeks but started up again). I disconnected the Ifit unit and now the thing work fine except for Ifit which I never used. Nordic track wanted to sell me a new console which cost more than the machine.
Manual for a Nordic Track Personal Performance
Go to iconservice.com click on to manual Input manufacturer : Nordic Track then model # NTL349050 and you manual await you.
Viewpoint 2800 the belt is not run
If the incline works but the motor fails to run, the unit has a faulty motor controller.
Viewpoint 2800 model# NTL14905.0 none of the keys respond. TV goes blank or has just red screen
Remove the cover to the motor compartment. Check the red LED on the LMCB. If it is lit constantly and not flashing in any manner, it is the console that is bad. The console runs $1600.00 which is more than the cost of the treadmill originally. Sounds like you are SOL unless you can find a used console somewhere. Good Luck.
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
