SOURCE: stitch problems
You can adjust the pressure foot(not footpedal)which puts the prsure on the foot by the needle. Also try altering the stitch length. If the stitches are skipping on silky fabric or knitted fabrics try using tissue and sewing onto that directly then tearing it off afterwards.
SOURCE: I have a Janome 1600P QC drags on a Little Gracie 2 frame
Sorry for your headache. It is the frame. If it is not level, balanced, you have hell to pay. Also it there is a nick in the grooves of the carriage tracks this will cause a machine problem. You may be able to repair the frame, or level it about the old level the table trick, put something under that part.
Good luck
SOURCE: janome 4900 sensor problem?
Maybe the bobbin winder is in the the on position. Push it to the off position.
SOURCE: how do you set the tension on a janome 6260 sewing
Refer to the manual.
You turn the tension knob - the higher the number the tighter the stitch.
First, thread the machine with the presser foot up. This opens the tension control for the thread to properly enter.
Then, when you lower the presser foot, the tension control closes to the setting you have selected.
Testimonial: "The fact that some one seems to think this model has a tension knob is slightly worrying but the information in the comment was helpful."
SOURCE: My Janome Harmony 1017 won't
when the fabric does not move then the feed dogs under the needle plate need to be checked to see if there up or down.
if the feed dogs are down then the lever or switch needs to be pushed up into the correct position
if the feed dogs are up & they are not moving the fabric like there suppose to, cause it's there job to move the fabric against the presser foot,, then they need to be check
the gears that do the zig zag stitches should be checked to make sure there not worn & weather they might need be be greased
