20 Most Recent Janome 6260QC Computerized Sewing Machine Questions & Answers
Here's Janome LO error;
LO: Replace the foot controller.
  1. Check for a tight or stuck clutch by the hand wheel.
  2. The machine may be jammed. Remove the timing belt to locate whether the bind is on the upper shaft or lower shaft. If it is the upper shaft, there may be thread caught in the take-up lever or crank pin. If the lower shaft is binding, check hook clearance, hook backlash. Check the lower shaft rear bushing for any black 'gunk'. If there is, replace the lower shaft and rear bushing.
  3. Clean the sensor on the DC motor and check if the shield plate on the motor is not loose or hitting the sensor. If either the sensor or shield plate is damaged, replace the motor.
  4. Check the upper shaft sensor. Make sure the shield plate is going perfectly thru the middle of the sensor. Replace the sensor and/or shield plate if damaged.
  5. If you still get the error, replace the DC Motor or upper shaft sensor (in this order).
My first thought is if you're running nearly non-stop for an hour the motor is overheating. Not sure what the maintenance schedule is for this machine <?>. May need a good cleaning/lube. Then foot pedal, then other.
Janome 6260QC... | Answered on Mar 07, 2019
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Thanks for using FixYa.
Janome 6260QC... | Answered on Aug 28, 2018
New needle, clean under bobbin case and look at this.......Looping thread underneath is a top thread tension issue...
I have written a 5 page illustrated Tutorial on overcoming this problem....HERE
Janome 6260QC... | Answered on Mar 08, 2015
where is your office location in Abudhabi?
Janome 6260QC... | Answered on May 06, 2013
I've had the Lo come on my screen of my sewing machine also, but normally when I turned it off it corrected the jam up.
Lo- A button is pressed when the machine halts due to a overload
wait 15 seconds to recover
if thread jamming causes the overload, remove the tangled thread
check the bobbin area for lint & loose threads
also check to see if the bobbin is warped
check you needle to see if it's bent-roll on a flat surface to see if it rolls correctly
if it's blunt it makes a popping sound when going thru fabric
let me know if these suggestions help
Janome 6260QC... | Answered on Feb 21, 2013
check with youtube or fixsewingmachines.com for a video on how to reset
Janome 6260QC... | Answered on Apr 09, 2012
Hi joycedowling...
You can download a free copy of the user manual for your Jqanome 6260 at the webpage below.
You will need Adobe reader to open it.
Here is a link to Adobe reader in case you do not have Adobe reader already installed on your computer.
Please take time to rate me
http://get.adobe.com/reader/?promoid=BUIGO
Below is the link to the User Manual
http://content.janome.com/documents/File/ManualFile/Inst%20book%206260QC.pdf
Janome 6260QC... | Answered on Nov 13, 2011
Manual for your Janome QC 6260, with a BOUNS.......HERE
sounds like the machine is out of order & needs to be serviced
Janome 6260QC... | Answered on Aug 02, 2011
Janome 6260QC Computerized Sewing Machine Logo
44 questions posted
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Janome Sewing Machines
Most Popular Question
lost manual janome 6260
  • Sewing Machines
