You are referring to the green led light on the front of the machine that tells you the brush is rotating? this is operated by a small magnet on the brush roll, when rotating it generates a small current to bring the light on. Remove the brush roll and check for damage behind the green led inside the case, also check for the magnet on the brush roll, ensure it is not missing and the brush roll is in the correct way round, magnet needs to be at green led end (ie to the left)
Magnet is fitted flush within the brush roll close one end and is around 6mm 1/4" diameter.
Green light not working will not affect the machine in any way.
SOURCE: the belt burnt out and it seems as though the red
It sounds as if there may be a piece of the broken belt in there. Look carefully with a flash light and remove any remnants you find, using a pair of pliers if you have to.
Also, remove the entire brush roller assembly and clean it up, once again looking for any debris that may cause an obstruction. If you can't clear the problem I recommend taking it to a vacuum repair as this is too expensive a vacuum not to. Good luck and write back and let me know if you have any questions. I have worked on a number of kirby's so I may be able to assist you further.
SOURCE: Brush Roller
The bearings can go bad in the brushroll. It may need replaced, even if the brushes aren't worn. Helpful link....
http://stores.ebay.com/CLICK-HERE-FOR-GREAT-DEALS_NEW-REPAIR-REPLACEMENT-PARTS_W0QQcolZ4QQdirZ1QQfsubZ3356845QQftidZ2QQtZkm
Marci
SOURCE: Roller brush not spinning?
THIS GEEN LIGHT MEANS THAT THE BELT HAS COME OFF. THE REPLACEMENT IS AS FOLLOWS: FLIP THE BRUSH (RUG RENOVATOR) OVER AND REMOVE THE SCREWS ON THE SILVER GUARD THAT KEEPS THE ROLLER IN PLACE. SLIDE THE ROLLER UP OUT OF THE SLOT, TAKING NOTE ON THE HALF MOON SHAPED SIDE. REMOVE THE OLD BELT(OR WHAT'S LEFT OF IT). PLACE THE BELT AROUND THE MOTOR SHAFT FIRST. THEN AROUND THE WOODEN BARE SPOT ON THE ROLLER. PUT THE ROUND(CIRCULAR) SIDE OF THE ROLLER IN FIRST, THEN CAREFULLY STRETCH THE ROLLER WHILE HOLDING IN THE ROUND SIDE IN ONE SIDE AND ROTATE THE ROLLER UNTILL THE HALF MOON LINES UP TO THE SLOT. PUSH IT DOWN INTO THE SLOT AND PUT THE ROLLER COVER BACK IN PLACE AND RE-INSTALL THE SCREWS. AND THERE YOU HAVE IT. HOPE THIS HELPS. PLEASE KEEP ME POSTED. THANK YOU FOR THE HONEST RATING AND FOR USING FIX-YA.
SOURCE: Roller brush will not move when vaccum is turned on
maybe the belt is broken. clean the unit and replace the belt.
