SOURCE: can't use bluetooth in lenovo g430 laptop
UNINSTALL ur bluetooth device through
"ON" ur bluetooth through the switch
Control Panel->System-->Hardware-->Device Manager-->Select ur Bluetooth device--> Right Click select uninstall...
Then download the latest driver from
Lenovo Y410
http://www-307.ibm.com/pc/support/site.wss/MIGR-68104.html
SOURCE: i have t61 lenovo laptop. frm yesterday the left
Highly suspect faulty mobo.
You can always buy / use ext mouse.
SOURCE: lenovo g530 4151 - restore bios from USB or CD ?
Hi, What I would best sugget you if you this kind of issue is to restore your system to its original settings, just look for the small button just beside the power button on your keyboard, it has an arching arrow logo, that key is what we called One Key Recovery that would restore your system to its original factory settings. but just a hint it would also delete everything on your computer so consider bucking up every important files taht you have before proceeding with the recovery. also make sure that the ac adapter is plugin before you press the one key recovery button then it will give the options to choose from, just choose one key recovey then proceed with the factory default recovery, thats it it would now proceed with the system factory default restoration. If you still need some clarifications regarding this issue you could also call the tech support hotline of lenovo
US/Canada: Available 24/7 1-877-4LENOVO (1-877-453-
6686)
Australia: Available 24/7 1300-557-073
New Zealand: 9am-9pm Mon-Fri 0800-446-833. Hope that helps you.
