Easiest way to remove and clean the inside of the headlight assembly. they are foggy
You cannot clean the insides. The are sealed if you attempt to remove them, which is a big job in itself, you run the risk of damaging the seal and allowing water and moisture to get inside which could lead to more problems. What I would recommend is to visit your local parts store, and pick up a bottle of Maguire's cleaner wax. Apply some of the wax directly on the headlamps and with a terry cloth or a microfiber cloth rub the wax in real good with a little bit of pressure. Allow the wax to cure and then polish it off with a dry part of the towel. Generally these headlamps oxidize and causes this foggy or cloudy appearance.
