When I hit start, an error code displays "od". The manuals solution is to lift the lid to start a new cycle both in on and off position. I did what was recommended by the manual but the error code still displays "od".
Usage: 3-4 loads per week
Purchased: Jan '05
Model: Maytag Neptune FAV6800AWW top loader washer
SOURCE: maytag neptune top loader model fav6800aww has an
rlbishop720,
See this post Left Hand Lid Lock Troubleshooting . I discuss Left Hand Lid Lock troubleshooting for error codes OD,OP FL, FO all related to Left Hand Lid Lock issues. I also provide a link to purchase a replacement Left Hand Lid Lock if you don’t want to deal with a DIY fix.
Let me know if I can help…..Rich
See if this post http://www.fixya.com/support/t4757262-i_have_a_letter_showing_and_it_say_o_d_w will get you started.
You have lost signaling from the Left Hand Lid Lock. If you want to DIY I will try to help........Rich
Google this ""Sticky: Neptune TL Washer FAV6800AWW""
I have repair notes to help you Troubleshoot and DIY the repair. 5 or 6 post down in the sticky you will find info to help you. This site is terrible for DIY folks. You have lost signaling thru the Left Hand Lid Lock to the Control Board.
There is a link to the Service manual in that Sticky. If you need additional help I will jump in............D*ick
Google "Sticky Neptune TL Washer FAV6800AWW" for the Service Manual and support for troubleshooting the OD error code.
Google this Neptune TL Washer FAV6800AWW
You will find FAV6800A or FAV8800A help. You have lost signaling thru the Left Hand Lid lock. At rhe location above tou will find common Service Repair notes for issues with the machine.
If you are going to troubleshoot you need the Service Manual.
LO error code:
Locked: Lid has failed to unlock -
the machine has repeatedly tried to
unlock the lid. Push lid closed to
make sure nothing from the inside is
pressing against the lid, preventing
unlocking.
Is that the issue? Have the Lid locks failed to release and you can't open the Lid?
Or have the Lid Locks released so you can open the washer lid but the error code LO remains?
If you want to DIY I will help you. Google this Neptune TL Washer FAV6800AWW This is a DIY Appliance repair forum no cost and you can get the Service Manual from this site. In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues with the machine. In that Sticky are other what I find to be common Service Repair notes for issues with the machine. If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air forum with your issue and we will try to help. No cost to you for the support..........D*ick
