Hi i have a problem to my internet. when i am enter to the internet explorer it hang. i change my hdd, i intall a new os. i have an IP add to my connection but if i connect to the internet it hang. please tell me what is the problem to my internet connection.ty
For me! i suggest you to changes in brodband connection.. cuz the Wireless Access is only depened on the area.. but the brodband you cannot wet longer to access anything what do you like... (tiger21)
Hi may be i can help you on it....htis could be a problem with memory on the comp..try this... click on run under start..type in %temp%..enter..u will see temp folder..emty the folder...delete everything...click on run again...do "msconfig"....u will see system configuration utility..click on tab "start up" ...disable all from the start up tab ..restart the computer...go to control panel ..click on internet options..delete the cookied ad files...close all screen...try the connection again...best of luck...
If Ie Hangs, the better way to narrow down the issue is to check with out browsers like Fire fox or opera. If you still have issues then we can sespect the issue is with the Net provider. To narrow down the issue try connecting any other friends computer at your home. If that works please write to we with the softwares you install after installing the OS. This might be an issue with Firewall or with TCP/IP settings. Or you can even try this http://www.cexx.org/lspfix.htm The above steps will narrow down the issue. please send me the error message if you see any. Good Luck.
Unplug the router and plug in back in and try to connect if that does not work to you have wep on if so turn off or write down the keys. It may also be due to the Ip is being use bu other pc/mac/dvr/printer
