I recently purchased a new nike presto watch (digital) and do not know how to change the time. Please help!
SOURCE: Adidas watch
Troubles you to help the solution to look for adidas the adx156 instruction for use, thanks!
SOURCE: how to set a nike triax watch
Press and hold in the mode button the seconds should start to flash.
Press top right button to select hour.
Press set button to advance hour.
Press top right button to select minutes.
Press set button to advance minutes.
Repeat this for the month/dte/dy/yr
Press mode button when done
SOURCE: How to set kenneth cole unlisted digital watch with 4 buttons
OK I'll do my best to describe the procedure...
Part 1:
Press mode button till the seconds window blinks
Press Lap/Reset button once to make minutes blink
Cycle through minutes using Start/Stop Button
Part 2:
Press Lap/Reset button once again to make hours blink
Cycle through hours using Start/Stop Button
(for this part, it's a bit tricky. Hours can be displayed in AM, PM, or 24 hour duration. AM is represented by "A", PM is shown with "P" and 24 hour mode is shown with "H", so keep an eye in the seconds window when setting your hour so you know for sure if you have the right hour)
When your done setting minutes and hours, press mode button again till you get to main screen
A helpful hint is to remember when setting up anything in this watch, mode will cycle through the different screens, lap/reset will change the value of whatever your modifying (AKA minutes/hours) and start/stop scrolls through the different fields.
Hope this helps. Sorry if it's confusing, best I could do.
SOURCE: how do you set the nike imara soar watch?
HI,
this is the user manual will help you to set the time.
http://safemanuals.com/user-guide-instructions-owner-manual/NIKE/IMARA-SOAR-_S
thank you,
vijay
SOURCE: Watch hands don't coincide with the digital time.
This usually occurs when the battery is changed. There should be a process for synchronising the two times detailed in the manual.
To get a manual you go to "http://tissot.ch/" and on the black menu bar at the bottom of the page you will see "product support". Click on this and you will go to a page of instructions. Download yours and find the relevant method for putting your watch right.
Testimonial: "You were right. I downloaded the manual and the synchronisation instructions were there. Still not sure how it happened. But thanks so much!"
