20 Most Recent
Nike Oregon Series WA0019-001 Wrist Watch Questions & Answers
I have the Niki Oregon
There are sometimes hidden dangers in replacing batteries which is probably why most makers recommend professionals to do the job.
You seem to have had some success but it sounds as if there is an intermittant contact with the battery. If you feel that you can remove the back again, try removing the battery, cleaning it with surgical spirit (to remove any grease that is naturally on fingers) and replace it.
As an engineer, I would expect that a screw on back should go on easily until it reaches the end of travel, when it will tighten. If it is stiff all the way, they you may have crossed the thread and damaged it. Never apply a large force at the start of screing the back on, as the threads are quite fine and may be easily damaged.
If after trying again, you still have the problem, then go to a watch repairer and discuss what you have done and the problem you are having.
Take care.
Good luck.
Replacement band for nike watch
I wear the smaller, womens' version of the Nike Oregon. Nice watch. I was attracted to it by the replaceable battery feature, but found out the strap goes long before the battery and the joy of ownership goes out the window with the price of Nike wrist-band replacement. I held onto my broken banded watch for awhile, and came up with a solution. First, don't try removing the screws that secure the watch-band pins. Not sure how they work, but I tried several times without luck. Even had a jeweler look at it without success.
I went to Kohl's and purchased a black velcro Timex replacement band for $8. Again this is the for the smaller version of the Oregon. The width of the timex band in 3/4". It includes a elastic band to secure the watch. This elastic band runs under the back of the watch and over the two pins. It is secured to a faux leather tab (with emblems), which is in turn attached to the velco band. Using a razor knife, I detached the faux leather pad from the velcro band and ran it under the watch pins, then reattached it with a touch of Gorilla glue. Be careful to wipe off any excess as Gorilla glue expands as it dries. Finally I blacked out the Timex advertising with a black felt permanent marker.
No reason to think this wouldn't work on the larger, mens' version of the same watch.
