20 Most Recent
Nike ACG Ascent WA0008 wristwatch Questions & Answers
How do you change the
Most digital watches have screws holding the back on, you will have to get a mini phillips screwdriver available in most stores. Remove all four screws, inside there will be a plate over the battery this plate may come up one of two ways, a screw which will require a regular screwdriver not phillips but still very small or the other way is the small metal plate has a tab you lift up you will need a magnifier to see this tab, once you pop it up batter will slide out. The battery will probably be a lithium style battery available at most stores. NOTE: there may be more than one screw that has to be removed on battery plate and sometimes you have to remove one side of watchband to get back off!
What is the AC terminal which I need to short with
The AC terminal is a little metal spot (usually a circle and usually gold colored) on the inside of your watch. Looking at the inside of your watch the "AC" should be labeled, though it may take a magnifier to identify it.
It may be labeled simply "AC" or it may have an arrow pointing to it. Once you locate it use a pair of tweezer or a paper clip and touch the battery and the AC together for a few seconds and release; you may have to do this twice.
NO ALT,WEATHER DISPLAY
Dreco,
I was changing my battery and ran into a small problem, too. I know where one spring goes, but I have another similar spring that may have fallen out of the watch (I was working on another different watch before, so I'm not sure if the 2nd spring belongs in the watch). One spring contacts the small speaker on the metal cover and will not affect the LCD display.
How many springs do you see in yours, if any?
