20 Most Recent
Nike Triax CV10 Wrist Watch Questions & Answers
Triax CV10
Nike Triax CV10 - Successful HRM reset 7 November
2008
I had real problems too. Even after repeatedly
following the known reset steps everyone else is posting up. Here’s how I got
mine going, please forgive the mind bogglingly tedious detail…
First make sure you’re using new good quality
batteries. I used Maxell’s, bought in 10’s from Hong Kong on ebay – no problem.
Second, and this is the ESSENTIAL bit…move right away
from the computer and any other electromagnetic sources before carrying out the
known reset…
Third, follow the known reset steps below, adjusted to
what worked for me…
If you press all four buttons of your Nike HRM it
will reset. Next time you go to "RUN" mode, it will show "HRM
LINK" error. You will now need to "hard reset" the unit.
Nike made a late change to add a "hard
reset" to the chest strap. To re-link (re-initialise) the watch you'll
need to open the battery door on the chest strap, and use a paper clip (or the
equivalent) to push the small gold button in the battery area. There should be
a small sticker in the battery compartment that points to the reset button.
The re-initialisation steps for the Nike C10 and
CV10 digital HRM's is:
(1) reset the watch
(2) open the battery door on the chest strap
(3) move the watch to RUN mode
(4) press the reset button in the chest strap
battery area without removing the battery
Tip - I agree with the suggestion to use a pin or
needle and definitely do it with the battery in the hrm.
Tip – Thumb holds battery to stop it from pinging
out, other hand performs jiggle with pin until the link is made (it links
straightaway if you jiggle it just right!)
(5) replace chest strap battery cover…and smile!
Can Link watch with Heart Monitor
If you can't link the hrm do as detailed in the following link
If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit.
Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button.
The re-initialisation steps for the Nike C10 and CV10 digital HRM's is:
(1) reset the watch
(4) press the reset button in the chest strap battery area
(5) put the battery back in the chest strap (if it's not already in - it's possible to push the button without removing the battery)
(6) hold both of the electrode to create a signal (probably not necessary - it usually links immediately).
My suggestion is to use a very thin needle and do it with the battery in the hrm.
Eventually, Nike will either eliminate the hard reset or update the manual to include this info.
How to change the time display
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all NIKE watch manuals.Rate me, please.
Nike triax watch
sounds like the contact inside for the ligt button is stuck on. Remove the back again and take a look at the contact under the light button to see if it is stuck, if so, GENTLY pry it out a bit so it's not touching all the time...
GOOD LUCK
Nike Triax Backlight
Usually after changing the battery you need to "ac" it, which means to restart the ic, or else the light will keep on. please check there is a area on the pc board says "AC". all you need to do is use a metal pin to contact it. if it dosn't work then try press all push buttom at same time, it has the same function as press "AC"
Tsai
Flashing display
Nike Triax Fury 100 SuperYou need to replace the battery. I had the same problem. Replaced the battery on mine and everything is fine now.
