LG LRSC-26922 Side by Side Refrigerator Logo
Anonymous Posted on Mar 06, 2017
No water/ice dispensing
My 6+ year old LG refrigerator stopped dispensing both ice & water a few weeks ago. A fwe months prior, there had been some low water pressure and was going to get a new filter (original), but normal pressure returned and never got around to getting new filter. The ice maker is grinding away just like normal, so called LG and a tech rep troubleshot it over the phone. He seemed to know what he was talking about and believed my problem was linked to the reversing solenoid. So I removed and inspected, but could not really detect anything wrong, so wrote part # down and re-installed, but water and ice is still not dispensing. Also, while looking over the solenoid mechanism, I could not determine how that might be causing both problems. I could see where it was needed for dispensing ice, but not water, so maybe I'm missing something? A replacement solenoid will run ~$25, so not big expense and easy to replace, but just not convinced the solenoid is my problem, or at least not my entire problem, so interested in what the experts think?
Jerry Beacom
Level 1:
New Friend:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Apr 18, 2017
Jerry Beacom
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
18
Questions
0
Helped
7739
Points
20
I would make sure all the doors are completely closed. If you can't completely close one of your freezer doors, you may have ice built up behind it. Take your freezer bin out and see if you have to defrost.
3 Related Answers
spankyII
  • 13 Answers
  • Posted on Mar 21, 2010
SOURCE: LG refrigerator won't dispense water any more
The water line is freezing in the door due to deteriorated insulation. The only fix I have found to work on my fridge was to defrost the inside door with a blow dryer. Then place a weedeater replacement line (the orange 10" or so size you find at Lowes' or Home Depot) up through the dispenser nozzle, If the line only travels about 3-4 inches up the nozzle, then ice is still in the tube. Blow dry it until you are able to get water to dispense. After the tube is ice-free, place the weedeater line up throuth the dispenser nozzle leaving about 1/8" sticking out. The dispenser will still work with the line stuck in it. The dispenser will probably freeze again in about 8 hours, But all you need to do each time this happens is to pull the weedeater line out, dispense the water to unclog the ice, and place the weedeater line back in the nozzle. I have been using this method for about a week now and it works great. My GE Side-by-side is also 4 years old and this seems to be a problem with all of them. There is a part you can order to fix the problem, but I have heard it may not work.
Anonymous
  • Posted on Jun 09, 2011
SOURCE: Icemaker fill leaking on new LG LFX28978SW french door refrig
Do you have the "dummy filter plug" installed and not the actual water filter in the upper left of the inside of the fridge?
spyder301975
Charles Dalton
  • 101 Answers
  • Posted on Aug 18, 2012
SOURCE: LG fridge LRSC26915SW -= water dispenser and ice are not getting water
Replace water filter, this unit had a issue with restrictions in filter due to a design issue. Water valve is all so called a water pump from many people.
The water dispenser is not putting out water and ice maker is not making ice. The fridge frequently cycles like it is trying to send out water.
it's still under warranty for up to 1 year,call whoever you bought it from and it should be repaired free of charge and next time you write send model number.
1helpful
3answers
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
7helpful
LG LRSC26923TT, water dispenser not working
I have a LG GRP207TUJA side by side freezer, which has a water,ice,crushed ice dispenser. There is a button to select which mode of dispenser. The freezer just appears to be cycling through all the selections all by itself and make the bleeping noise as it moves from one selection to another...any ideas
Sep 15, 2009 • Freezers
10 yr old Frigidaire ice maker stopped making ice
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
14helpful
5answers
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
1helpful
3answers
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
