A
Anonymous Posted on Jul 03, 2013
Service manual xerox 5830 - Xerox 5830 Copier
CODE INCIDENT : 06-320
Check-Replace CAN3 PWB
I picked up a 5830 copier and a paper jam is in the LCD I followed the instruction, and there is no paper caught into the area per the displayed area or in the paper path period. Code is D3-1 Do you have a...
The machine has been sitting around for a while, or was just been stopped being used.
Try cleaning the brown roller in Tray 2.
Try the other paper trays see if they work. Tray 1 and tray 3.
We would need more information about the results of these areas and how it worked.
If there is alcohole, try cleaning the brown roller. The other rollers are harder to see. This machine could even have bad paper feed clutches.
A xerox serivce call would have to be placed to do the major repairs.
3helpful
I have forget my user code
if it is a 5830 model, go to the menu and look for tools.
type "1111" and hit enter
sometimes it can be "11111" and see if it works.
I hope this is the area you wish to enter.
If it is the auditron mode, place a Xerox service call for the service rep.
2helpful
2answers
Dislplay reads "not ready"
Try this reset.
Power the machine off, Hold "0" the zero key while powering the machine on. That will put it in diagnostics mode.
Then enter 20, press start, then enter 3 and start.
Power off and back on and let me know.
Message light won't stop flashing on my AT&T 5830
I took the phone apart and disconnected the led light. Worked!!!! lol
1helpful
Code error 06-43 et 06-40 copieur xerox 5837
Dear sir; Thank you to bring out the question to refresh my memory, I hope is correct! the error code 06-43 or 40 that all belong to optical problem, my suggestion ;
1, remove the glass plateform
2, check the exposure lamp continuaty, if nocontinuaty replace it.
3, check the exposure thermos fuse continuaty,if no continuaty replace it.
GOOD LUCK, if you need more help let me know
HAVE A HAPPY HOLIDAY !!!
Rank xerox 5328 U9
if its a u9-1 code it is the lamp that is faulty. Sometimes it can be the connections either end of the lamp but normally the lamp itself. It will probably cost as much to fix as it would to get a new one to be honest
Xerox 5830 Poor print quality
The best place you can get a manual and parts from are here..
https://www.partsdrop.com/store/
Ask for Britt if you call. But I deal with them all the time.
I am sure they would have all you need.
No this is not where I work, I would not do that. But they are the most reliable parts place I have found.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
