20 Most Recent Xerox 5830 Copier Questions & Answers
Check-Replace CAN3 PWB
Xerox 5830... | Answered on Mar 26, 2011
the problem is its dp unit
Xerox 5830... | Answered on Dec 12, 2010
problem :
can't find the counter
solution :
Press the ‘Review” button on the Control Panel. The Review button is just below the Information “i” button. The “Total Copies” will be displayed on the bottom, left corner of the Touch Screen
Xerox 5830... | Answered on Aug 19, 2010
if it is a 5830 model, go to the menu and look for tools.
type "1111" and hit enter
sometimes it can be "11111" and see if it works.
I hope this is the area you wish to enter.
If it is the auditron mode, place a Xerox service call for the service rep.
Xerox 5830... | Answered on Oct 26, 2009
The machine has been sitting around for a while, or was just been stopped being used.
Try cleaning the brown roller in Tray 2.
Try the other paper trays see if they work. Tray 1 and tray 3.
We would need more information about the results of these areas and how it worked.
If there is alcohole, try cleaning the brown roller. The other rollers are harder to see. This machine could even have bad paper feed clutches.
A xerox serivce call would have to be placed to do the major repairs.
Hello sir; you have a bad copy cartridge, replace it !
Well, most of the copiers are having dept code features where u can set access code for the copier. But the setting is depends on the brand & model.
If you donot find paper in the machine check for a stuck actuator or a bad sensor.
Try this reset.
Power the machine off, Hold "0" the zero key while powering the machine on. That will put it in diagnostics mode.
Then enter 20, press start, then enter 3 and start.
Power off and back on and let me know.
2 things primarily.
1 is dirty optics. Remove the glass, and the black optics tub. clean all the mirrors the lens and the lamp and the surrounding area around the lamp.
2. The copy cartridge may need replaced.
If the backgroung remains pretty consistant, it is most likely the optics.
If the backgroung get worse as the machine runs, or is different every other page, the problem is the copy cartridge.
Dear sir; Thank you to bring out the question to refresh my memory, I hope is correct! the error code 06-43 or 40 that all belong to optical problem, my suggestion ;
1, remove the glass plateform
2, check the exposure lamp continuaty, if nocontinuaty replace it.
3, check the exposure thermos fuse continuaty,if no continuaty replace it.
GOOD LUCK, if you need more help let me know
HAVE A HAPPY HOLIDAY !!!
Xerox 5830... | Answered on Dec 21, 2008
if its a u9-1 code it is the lamp that is faulty. Sometimes it can be the connections either end of the lamp but normally the lamp itself. It will probably cost as much to fix as it would to get a new one to be honest
Xerox 5830... | Answered on Dec 01, 2008
That error is due to a problem with the MD Board. The most likely cause is the MD Board and needs to be replaced, link below for part needed.
http://www.iteminconline.com/960K38900_960K38900-960K38901-960K38902-Xerox-Workcentre-7425-MD-P.htm
Xerox Office... | Answered 21 hours ago
23 questions posted
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xerox Office Equipment & Supplies
Most Popular Question
forget user code
  • Office Equipment & Supplies
