Where do u find the PIN number for a wireless -g broadband router Model no WRt54g-rg
SOURCE: how to setup the pin number for my wireless
when you say pin number , do you mean the SSID number for security ? plug in the router using the ethernet cable , open up the browser, ie or firefox etc,goto the admin address, it may be 192,168,2,1or 192.168.0.1 etc
SOURCE: Linksys Wireless G Router Model WRT54G
It didn't work for me.
Should the username be the email address from At&t that controls the DSL line, or should it be the username to get into the Netopia modem?
SOURCE: i need pin number for my Belkin router F5D7234-4 v-1000
If you have forgotten your WEP Key and need to start over you will have to reset your router. On the back
The "Reset" button is used in rare cases when the Router may function improperly. Resetting the Router will restore the Router's normal operation while maintaining the programmed settings. You can also restore the factory default setting by using the "Reset" button. Use the restore option in instances where you may have forgotten your login password.
Push and release the "Reset" button. The lights on the Router will momentarily flash. The "router" light will begin to blink. When the "router" light becomse solid again, the reset is complete.
Restoring the Factory Defaults
Press and hold the "Reset" button for at least 10 seconds, then release it. The lights on the Router will momentarily flash, The "router" light will begin to blink. When the "router" light becomes solid again, the reset is complete.
Configure the Router Using the Web-Based
Using your Internet browser, you can access the Router’s Web-Based
Advanced User Interface. In your browser, type “192.168.2.1” (you do not
need to type in anything else such as “http://” or “www”). Then press
the “Enter” key.
Logging into the Router
You will see the Router’s home page in your browser window. The home
page is visible to any user who wants to see it. To make any changes
to the Router’s settings, you have to log in. Clicking the “Login” button
or clicking on any one of the links on the home page will take you to
the login screen. The Router ships with no password entered. In the
login screen, leave the password blank and click the “Submit” button to
log in.
SOURCE: Can't find PIN for or on my Linksys Wireless Router
There is a small red button on the back - Press it gently for 30 or more seconds to reset to default.
Default password is "Admin"
Get the software at www.linksys.com/support
Step 1:
Flip the device over.
Step 2:
You should find the model number on the sticker underneath the device. See the image below.
NOTE: Take note of the exact model number and version of your Linksys device. In this example, the model number of the device is WRT54G v5.
Step 3:
Check the serial number which is located right underneath the model number.
NOTE: The
images may vary depending on the model number of your Linksys product.
If there is no version number beside the model number it means the
device is a version 1.
you get it number?
then try again connet with it and enter the pin code same like you get from router
<click here for instruction to setup your router>
