Has anyone come across this before? We have had our TV for approx 3 years now. Nothing has changed ie - TV configuration same as the night before - no loose cables etc...
However, 2 nights ago, switched on the TV to find what can only be described as 'missing pixesl' in a line about an inch from the top and an inch from the bottom of the screen.
Is this a sign that the TV is shot and needs repairing/replacing already? I hope not!
Are these lines visible regardless of what device (DVD player, cable box) you are watching? If so, then yes, it appears the LCD panel is failing. If you only see the lines watching one device, it could be the cable/wire or the device itself. Now it can also be the related input jacks too so connect the device to another input to be sure.
Thank you for quick reply. Yes, they are visible for all external inputs (TV, satellite, amplifier, DVD). The only time they are not visible is when we select "Photo" from the menu or the 2nd picture when you use twin picture function.
