SOURCE: netopia adsl modem
I don't understand what you mean by "Unlock" the USB? I presume you perhaps mean how can you "Use" it? The USB Port. What needs to done in this case, is to Install the "Driver" that will allow the "System" to "See" the USB Device.. When you plug the Device into the PC, with ya USB lead, the PC should "See" it, beep twice, and if it hasn't been installed B4, will, if it cannot find any "Generic Drivers", then, "Ask" for "Drivers". (These may be on CD etc.) When windows has installed the USB "Drivers" your device will be ready to be used. Some Modems have Both an Ethernet connection & a USB one too... this allows two (2) ways to connect it to your "System" OR two (2) ways to be connected to the modem for two (2) PC's simultaneously. The Ethernet one generally has the address 192.168.0.*. Whereas the USB one is generally 10.0.0.*,or 10.1.1.* You can also "Bridge" these two together.
