20 Most Recent Linksys Wireless-G WRT54GS Router (e125894) Questions & Answers
Router setup
You do not have to use the cd. Follow these instructions:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Linksys... | Answered on Aug 28, 2018
https://watchonlineclub.com/watch-online-gold-full-movie-2018.html
can you tell me the company name of router?
then simple solution a small hole at the back side of router you can see. use a small pin and insert it in ... then router will reset the settings.
go to browser and use this IP address (192.168.1.1) in address bar after connecting to browser.
then use the admin admin user name and password.
Linksys... | Answered on Aug 16, 2018
I had this issue and did not work untill I downloaded the software provided by linksys see if you download it and may work for you as we need to go step by step to fix the issue or you can get it from linksys too at: http://www.linksysbycisco.com/US/en/products/WRT54GL
Let me know if that work for you and please do not forget to rate the service so we can improve on it…
Linksys... | Answered on May 09, 2018
Reset the router to default....the default username and password is usually on the bottom of the router..then open a web page on your pc and connect the router with a network cable..type 192.168.0.1 or 192.168.1.1
Use the generic name and password to logon....once logged in, configure username and password and wifi...once setup..save and exit..disconnect and connect router to internet modem...log onto pc and look for your wifi neteork name..cheers
Linksys... | Answered on Jan 24, 2018
hi try this before you hit the reset botton. Check if Windows XP firewall or 3rd party firewall are blocking the pings, and temporarily disable them just to be sure. The WRT54GS has a feature called "AP Isolation", It's on the "Wireless -> Advanced Settings" page. You won't need it for home use so turn it off as well. Last thing, do a firmware upgrade. Hope it's helps Good luck.
Linksys... | Answered on May 02, 2017
Very hard to say without getting into more technical details. Sounds like you may have a bad router, but more likely there is something wrong with the setup. You probably need someone with technical expertise to walk you through all the steps.
Have you tried calling Linksys tech support? They may be able to help. Also, you might try buying a different router just to give it a try. I've had good success with Netgear in addition to Linksys. I generally stay away from DLink.
Do you know your SSID and password for your wireless account?
I’m happy to help further over the phone at https://www.6ya.com/expert/tami_f8d2d553d5094045
Linksys... | Answered on Mar 31, 2017
LOST ROUTER LOGIN PASSWORD
If you have forgotten your personal router login password there is no way to recover it. You will have to reset the router. This means all the settings on the router will be reset to factory defaults. It also means that all your connected devices will need to be connected again with the new security information (WEP, WAP, etc,) . You will need the default admin login name and the default admin password. This can be found in the user guide that came with the router. This can usually be found online at the router manufacturers site.
There is usually a button or a switch hidden in a pinhole opening on the back of the router. Pressing and holding the switch for 10 seconds or so will cause the reset and usually the LEDs will flash and blink for several seconds as the router firmware resets and clears out the old information.
If you are trying to get into someone else's router illegally there is no way to find out their login password.
For future reference, write the password down, or a hint at what the password is, on a piece of tape and secure it on the bottom of the router. I use my cell phone memo function to store all my passwords.
Linksys Home Networking
Linksys... | Answered on Mar 06, 2015
I had some also facing same issue with my router. I tried a lot however nothing helped me, I just visited LINKSYS Tech Support
and made a call on their toll free. I got instant help for my router by a certified technician.
Hope this will help you
Linksys... | Answered on Jun 24, 2014
you dont need cd installation to configure linksys router
goto ip addrees default ip is 192.168.1.1
is going to take you to configure setup screen
i can give you suport i work for linksys and verizon internet
Linksys... | Answered on Jun 23, 2014
Welcome to fixya
Yes ipod touch support linksys WRT54gs router.
Thanks
It seems that the installation files from the disc is corrupted. I suggest that you first connect your laptop to another router so you can download the drivers from Linksys Support Site. Under Downloads tab, you must choose the right version which can be found at the bottom of the router. Then install the said drivers before you connect to the WRT54GS router. Hope it helps.
You download the software needed to configure your Linksys wireless router from Linksys website.
If you have version 7.2 click below
http://downloads.linksysbycisco.com/downloads/WRT54G-v7.2_Setup_Wizard,0.zip
If you have version 7.0 click below
http://downloads.linksysbycisco.com/downloads/WRT54Gv7-EU_v7_00_4,0.zip
Take your pick.
It sounds like you may be having IP address conflicts. Many Xbox users have a fixed IP address set in their unit and then have a Port Forwarding done in the router to provide faster play. If you reset the router all this is lost. Then what can happen is that the router will assign a device the reserved IP address of the Xbox. When you turn the Xbox on, then it cannot connect as there is another device already assigned that address. Reconfiguration is required to prevent IP conflicts.
Linksys... | Answered on Dec 11, 2013
Linksys Wireless-G WRT54GS Router (e125894) Logo
725 questions posted
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Linksys Computers & Internet
Most Popular Question
wrt54g router default pword not
  • Computers & Internet
