20 Most Recent
Netopia (3342) Modem Questions & Answers
Can't find drivers for net
this device may not work in the 64 bit mode because it is a 32 bit device and the driver may not be available for it in the 64 bit mode. The manufacturer is the place to get the up dated drivers.
I suggest using the device in the Windows Vista or XP mode and the drivers should work for this device.
Drivers wont install on win7 64-bit
Correct the 64 bit driver for this was in beta and they have not got that to work ether so you best bet here is 32 bit you should have got two disc with you windows 7 OS. 64 bit right now does not work with all hardware so keep that in mind. Sorry to deliver bad news but 32 bit or look for another hardware solution.
Thanks and pelase do not shoot the messenger and leave some feeback Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Problem with my Arris Comcast cable modem.
I just had a tech out yesterday regarding this problem on a TM402 - restarts under high network saturation (big uploads or downloads). According to the tech, this is a know issue. Comcast upgraded their network to support multiple carriers (called channel bonding) dynamically. Due to this upgrade, when your modem is demanding high bandwidth for large downloads, essentially, it requests an additional carrier (or channel)...when that request is initiated, the modem's hardware (and firmware) can't connect to more than one channel at a time, therefore, it "gets confused" and restarts itself to attempt to fix the problem. I upgraded to the TM602, and the problem is still there. This is because the channel bonding feature requires a Docsis 3.0 capable modem. The Arris TM702 is the first in the Arris line to offer docsis 3.0. I called Comcast and they are upgrading me to the Arris TM702 (which is a 50M down/10M up service, btw) for an additional $30/month - well worth it for the stability which I require.
As far as Comcast saying that it's fine, call them back with the information I provided, and ask to get you to a tech who can better service your needs...unfortunately, the "tier 1" techs don't have a clue.
Constant d/c
Do you have call waiting and is it turned off? If not turn it off, please.
How to port forward on Netopia 3347WE
1. Click the Expert Mode link near the left of the page.
(it is not listed in the manual)
2.Click the Yes, enter expert mode button near the centre of the page.
3. The menu on the left should change. In this new menu, click Configure.
4. You should now see a new menu. In this new menu, click NAT.
5. Click the Define Custom Service button near the center of the page.
6.Put a dot into the Port Forwarding: Range of Ports radio button. 7. Click the Next button. Then set up the ports you want to forward. One Example s here
O
Port Forwarding the Netopia 3347W Router for Xbox One
3/15/2015 8:16:11 PM •
Netopia...
Answered
on Mar 15, 2015
Reset the password on my Netopia 3347-02-1006 router
Hi You can fix this problem by entering 192.168.1.1 or your routers ip.then you can accsess your routers software and in the WLAN section you can change the password or reset. try looking under every section until you find the correct area which you can do things to the WLAN setting. Hope this worked :)
12/26/2014 11:53:14 PM •
Netopia...
Answered
on Dec 26, 2014
Reserve ip address
It all depends on the brand of your router, but mainly is to jump into the GUI with your admin password, look for DHCP options, static DHCP and save the MAC Address of the host with the desired IP.
7/1/2014 9:22:50 PM •
Netopia...
Answered
on Jul 01, 2014
Need password
"Try http://www.fixya.com/support/r11153882-general_routers_reseting"
5/29/2014 12:13:10 PM •
Netopia...
Answered
on May 29, 2014
