Compaq Presario 700 470024-192 Notebook Logo
Posted on Mar 19, 2009
Disable Touchpad Clicking
I want to disable the touchpad from being the ''left click'' and just use the buttons below the touchpad. Where can I do this? I tried control panel/mouse and that didn't work. Please help.
Esli stavenga
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Sep 21, 2013
Esli stavenga
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
899
Points
13
You can hit the upper-left corner for 5 seconds.
if it is all right the mouse pad needs to disable himself
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Mar 20, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
713
Points
7
Hiya, At the bottom right of the screen, by the clock, you should see an icon for the touchpad.....
Hint : Hover the mouse over the icons and wait for the "Pop-Up" Display to see what they do if your not sure.
When you find the one for the touchpad, simply right click it and scroll down to the option that says "Tap To Click" and left click it so that there is NO TICK next to it..........
........ This will DISABLE all tap click options and leave the touchpad as a touchpad and the buttons as buttons...........
Hope This Helps, Kind Regards,
Me :D
How do i disable touch pad when mouse is in use
      Click the "Start" button and click "Control Panel." Click "Hardware and Sound" and click the "Mouse" link under Devices and Printers to open the Mouse Properties box. Click the "Touchpad" or "Buttons" tab depending on your PC, then select the "Disable" option next to thetouchpad installed on your computer.
      How to Disable TouchPad While the USB Mouse Is Plugged in
      smallbusiness.chron.com/disable-touchpad-usb-mouse-plugged-52685.html
    Feedback
    How To Turn Off Touchpad When Mouse Is Connected In ...
    www.intowindows.com > Windows 10
    Dec 14, 2015 - How To Turn Off Touchpad When Mouse Is Connected In Windows 10/7/ ... who always use a mouse and don't want to use the built-in trackpad ...
    How to Disable Your Laptop Touchpad ' PCWorld
Disable touchpad
Hi
look for a FN + some key (F3-F12) combination to turn the touch pad off, there can also be a button next to the power button to switch touchpad on and off.
You can also try to disable it using windows itself by right clicking the touchpad software (by the system clock )and in it's settings look for an option to deactivate the internal touchpad.
Hope this helps.
The touchpad is locked
On some models there is a button at the top of the touchpad in the middle that toggles the touchpad on or off.
On other models you simply tap twice in the upper left hand portion of the touchpad to toggle it on or off.
And then there are some models that you use keystrokes to toggle the touchpad. Normally you would Press and Hold the ALT or FN function key near the bottom left portion of the keyboard then hit the key that toggles the touchpad. The key that toggles the touchpad will have the icon of a finger pointing at a square which represents the touchpad.
Below is what I found in your user manual on the touchpad. It looks like your touchpad is controlled by software and there is no button or keystrokes that control the toggling.
Customizing the Touch Pad and Track Stick You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
  1. Open the Control Panel, click Printers and Other Hardware, and then click Mouse.
  2. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad and track stick.
    • Click the Pointer tab to adjust touch pad and track stick settings.
  3. Click OK to save the settings and close the window.
Below is a link to your manual
http://www.support.dell.com/support/edocs/systems/wsM70/en/ug/keyboard.htm#wp1052329
11helpful
Where is the touchpad lock on the Hp probook laptop.
Hi.
Turn off the touchpad Most HP notebooks come with an on/off button near the touchpad. If you do not wish to use the touchpad at this time, press this button. Press it again when you wish to use this accessory again. If the notebook does not have an on/off button for the touchpad, touch and hold the top-left corner of the touchpad for approximately 5 seconds to disable it and do this again to activate it. When the touchpad is disabled, a small light will illuminate on the touchpad and an icon will appear briefly of the touchpad with a line through it. When the touchpad is activated, a small light will turn off on the touchpad and an icon will appear briefly of the touchpad. Alternatively, if the notebook does not have an on/off button for the touchpad, and you wish to turn the touchpad off, open the Mouse Properties window, select the Device Settings tab, and click the Disable button. You may re-enable the touchpad from here at any point.
Regards.
How do I disable the touch pad on my Latitude E5400? The curser jumps all over when I type. On my other laptops, there is a button clearly marked to disable the touch pad and this has solved the problem....
  1. Click Start.
    Go to Start, click Run, type main.cpl in the box next to Open, click OK.
  2. Click the Dell Touchpad tab.
  3. If you are not getting the Dell Touchpad tab, update your driver, you will get the Tab.
  4. Click on the picture of the touchpad.
    Click Device Select.
    Click to check the box to the left of Disable Touchpad / Pointing Stick when external USB mouse is present.
    Click Apply, then click OK.
  5. Click the X in the upper-right corner to close the Dell Touchpad Utility.
I want to disable the touchpad on the acer aspire 5532 but cannot seem to do it please can you advise
You can disable it by doing one of these 2 steps:
1.If you want to uninstall the driver "FOR EVER" you can uninstall it from the device manager page from the search toolbar.
All the steps are down to see where is the uninstall button.
I prefer to backup driver using the free driver updater and backup DriverMax.
2. If you want just DISABLE it do the following:
Search for device manager
Click on Mice and other pointing devices tree,
there would be a touchpad driver usually its Synaptics
Disable it by clicking right click and then Driver tab and then disable button, you may see the disable button disabled, that is because you don't have another mouse instead of your touchpad, install your mouse drivers then you may can disable it.
1helpful
2answers
Touchpad has stopped working, can you help?
Hi there don't worry. Its disable that's why not working. Please press FN+F7 and try. The symbol on your keyboard is below. Just press FN+ below mention symbol. Thanks.
1helpful
2answers
Hp Paviliion dv4-1365dx .....When I type all of a sudden the cursor will jump and I'll be typing into what I have already typed (just did it)....very frustrating HELP!
Unfortunately the touchpad of most laptops is very sensitive. This will cause the slightest nudge of the thumb or wrist to move your mouse and possibly even "click". In order to avoid this issue and associated frustration, I always 1) disable the touchpad when I have an external mouse plugged in and 2) disable the "tap click" feature. Follow the instructions below for these two suggestions.
Disable touchpad
  1. On my system there is a small button just above the touchpad that disables it, yours might as well. If not, go to Start>Control Panel> Mouse>Device Settings>and Device. Highlight the Disable Button.
  2. Follow the same steps as above but instead of Disable button select Device button and select the Tapping option and unselect "enable tapping".
Good Luck,
NOLA Tech
1helpful
How do I disable touch pad when using a mouse? ASUS K50IJ Win7 64 bit
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
Unfortunately, there are no keyboard shortcuts to enable/disable Touchpad movement or tapping. You can however drag the Mouse icon from the control panel to your Quick launch bar for quick access.
If that sounds too much effort, you may consider adjusting the sensitivity of the touchpad. This can be accessed from the Touch Pad tab of our mouse properties. Choose a low setting.
You can also go to link below to get help.
http://labnol.blogspot.com/2007/05/disable-touch-pad-of-your-laptop-avoid.html
How to disable the touchpad on a compaq cq40?
you dont to disable touchpad.all you have to do is to uninstall the touchpad by clicking on start goto controlpanel,click on install ro remove program,click on touchpad and click remove
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
