The battery went dead ,when i atached the cord and powered up, the screen was black read "no O.S found".It will load up recovery mode by pressing f8 but when i try to reset to factory default it fails at the end.i cant remember if a recovery disk even came with it,i dont think it was even included beacuase of the recovery partition ,so how do i fix this with out spending cash?
SOURCE: acer webcam
your drivers are eathier not installed or one corupt, you might be able to find the drivers at this site, http://acer.com/support/download.htm
SOURCE: i want recovery cd for acer extensa 5620.. please
u can restore ur computer like this when u dont have Recovery CD for ur Laptop and when ur OS is set then u can make One from Acer E REcovery Software
Acer: When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
Pls rate me Fixya for help more questions are welcome !
SOURCE: Acer Extensa 5420 won't turn on, not a power/battery problem.
Just for the heck of it, try blowing out the cooling fan with some compressed air. If you have never cleaned it and the fan stops turning, the computer will go into a safe mode and not start up.
Ther should be a vent somewhere on the side of the laptop that vents hot air cooling the CPU. That is where you need to blow it out.
Hope it helps- just a longshot...
SOURCE: Acer recovery disk download
http://www.restoredisks.com/index.asp
Just ordered for my acer aspire 5315
SOURCE: Acer Extensa 5420-5687 laptop won't turn on
Okay, Here's the deal..... I recently had the same problems with my friends' Acer Extensa laptop and here's what I did to fix it. I narrowed the issue down to two culprits 1. Overheating, 2. Defective Motherboard. I have fixed the problem but I takes time, patience and some technical ability which may not be available to some. :( (Swapping out the motherboard MAY fix the problem but if the defect is in the manufacturing process then the problems could return). Here's how I fixed it... While in the process of disassembly I noticed a small electrolytic capacitor that had seemingly broken off and had become wedged between the frame (<ital>very lucky! this gave me the clue I was looking for!</ital>). This made me think that it had broken off the motherboard. I proceeded to disassemble the laptop and found the location of the missing capacitor (there are two located right next to each other on the board) and was able to re solder the capacitor back onto the motherboard (could it be a manufacturing processing defect thats causing these to break loose? ). Mine was broken off due to what looked like bad solder joints. Your capacitors could still be attached but have weak solder connections. Also while i had access to the motherboard, I used the opportunity to clean and re apply the heat sink compound to the CPU and thoroughly clean the fan vents. I then reassembled the laptop and EVERYTHING has been running fine now for the last 3 days. Total time was about 4hrs and it cost NOTHING to repair. GOOD LUCK :)
