20 Most Recent
Acer Extensa 5420-5687 Notebook Questions & Answers
Can i watch tv though my laptop
You can watch TV on your laptop, but you need to purchase an USB TV tuner and plug it into the laptop's USB port plus install the TV tuner software.
There are several manufacturers that make these USB TV tuners, I suggest you do a Google search for these devices for the best deals.
Need to copy a dvd that is not copy protected
Hi
Your laptop does have a DVD re-writer which is needed for copying DVD's
You will need to purchase some blank DVD's firstly to copy your project onto
Secondly if you click Start>Porgrams>Accessories>Windows movie maker, you can use this to create your project, there is a tutorial on there to help you get through the software
Regards
Shauqat
DVD is not recordable, Acer Extensa 5420
Just put in the blank dvd without trying to burn anything to it and see
if your pc see's the blank dvd, if not find one that is recognized by your pc. After you put in a blank dvd, it should show under my computer in the drive and should be able to open it like a folder, or
windows will pop up a little window that ask's if you would like to burn anything to the dvd.
Acer extensa 5420 bios
Clean out the cooling fan/vents, etc. and try again. If the fan isn't turning, it won't boot up.
If that doesn't work, you may need to disconnect the power supply and battery and then hold down the power button for 30-60 seconds. This will discharge stored energy from your laptop. I'm not sure of the specifics, but this happens to mine every 12-18 months or so. Once you've done that, reconnect the charger and battery and try to power up again. It should work now.
If these steps don't fix it, you have serious problems.
Why won't my laptop turn on?
Take the battery out, unplug the charger, etc. then hold the power button down for a full minute or so. Then put the battery back in and connect the charger (if necessary) and it should power up and operate normally.
I have to do this to mine about every 12-18 months, but other than that it's still going strong for nearly 10 years of nearly daily use.
Acer Extensa won't boot
if your computer has the history of repair, i suggest you have to take it back to the technician and check if all hardware are properly installed. if not, it maybe a short circuit on your board.
thanks
How to activate webcam
http://www.amazon.com/Acer-Extensa-EX5420-5687-Double-layer-widescreen/dp/B000OTAA66 please download the driver this webside
