20 Most Recent
Acer Extensa 5630-6806 Notebook Questions & Answers
Acer extensa 5630ez won?t turn on.
Can you give a location of R138?
Is it on the easy side? E.q. the side of the motherboard wich is accessible by removing the bottom plate? I see Q24, located close to CPU. If possible, post a picture of R138, with some components visible.
My acer extensa 5630 will not start
The problem maybe the RAM, it could be faulty or just needs
reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then
remove the RAM module/s and take them to your friendly computer repair shop and
get them to test the RAM for you.
Just like you sometimes need a mechanic to repair your car,
sometimes you do need a technician to diagnose and identify the fault or faults
on your computer. Not only does a good service technican have the experience to
deal with this type of problem, they also have the equipment that allows them
to look at things the average computer user can't see, and he has a collection
of replacement parts that can be used to quickly test individual components on
your computer.
My wireless wont work on my extensa 5630ez
Step 1:
Hey There,Try googling Acer Extensa 5630ez drivers and then select the acer website.Step 2:
You should now be able to select your Acer Model and will be directed to the Driver section.Step 3:
Select the Network Drivers for your Model and download those.Step 4:
After Downloading you simply have to install them and most probably Restart your Computer.That should be all. Hope i could help.GrsBen
My acer extensa keyboard not working
Please run system in safe-mode and see if it works then.
If both the keyboard and the touch-pad are not working, please remove the battery and run laptop on A/C.
If that doesn't help, reseat the keyboard cable on the mainboard.
If all fails, replace keyboard - It's a few US $
I need the Service Guide for my laptop, for freeeeeeee!.
no free service guide !
what do u want to do i can guide u tell me
see these links for repair info very useful
http://www.laptoprepair101.com
http://www.laptopparts101.com
http://www.cyfinity.com/category/repairs/
pls rate me fixya if u got help
Acer Extensa 4420 overheating
The laptop must be dismantled to access the motherboard, buy a can of compressed air attach straw. Now remove fan and the heatsink, blow out all open ports and fins on the heatsink and fan, next! remove thermal grease from the processor and heatsink with rubbing alcohol and a paper towel, now! apply fresh thermal grease to the processor and heatsink, "small thin layer evenly spread" now assemble, "solves most heat related issues"
No disiplay on the screen of the laptop and on the external monitor
No display on either? Does it sound like the computer completed the boot cycle? Do you hear fans running and the hard drive spinning?What happens when you hit the power button? Do you hear any beeps or see any blinking lights? Does anything post to the screen during the boot cycle?If the boot cycle completed and you see no display on either monitor, then your video card is bad.
