i have a D: 8234 and 8233 message on my screen which is also blue, lens in open position. i have a D: 8234 and 8233 message on my screen which is also blue, lens in open position.
You can't post conmments that contain an email address.
Hi, The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option. Performing a manual power reset Turn off the camera. Remove the battery pack. Press and hold the power button for 30 seconds. Allow the camera to remain without power for 60 seconds. Reinsert the battery pack. Turn on the camera. You can reset the Camera back to factory default by performing the following steps: Press the power button. Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed. Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult. This should resolve the issue. If the issue persists, service may be required.
RESET YOUR MOBILE TO FACTORY DEFUALT BY TYPING THE CODE BELOW ON YOUR MAIN SCREEN:
2945#*#
AFTER YOU TYPE IT ,MANY OPTIONS WILL APPEAR ON SCREEN,CHOOSE FACTORY RESET
Hi, "E18"indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error. Thank you !!
remove the battery, let it sit for at least 2 hours, then put it back.
put the batteries back, then gentle push the lens sideways to free its stuck part. if the error still occurs and the lens is not retracting, consult the
warranty for the device as the lens assembly gears may be at fault.
the lens doesnt go back and errors are on a blue screen 5F08, 8233, 8234
