20 Most Recent Olympus Stylus 760 Digital Camera Questions & Answers
It's a little tricky but with a small eyeglass screwdriver and some super glue you can do it. I had the problem, here is what you do. 1 romove the five screws two on bottom NOTE one of the bottom screws is longer than the rest. two on side one on other side. 2 gently remove housing, 3 then remove chrome ring that surrounds three sides of camera. 4 inside there are four screws remove them and separate camera. there is a small metal clip that came unglued you can see where it belongs you must gently turn the wheel till the retainer is all the way to the left away from wheel.the clip goes under the shaft use a little super glue to glue it back. the hardest part is the screen plug lift up black piece line it up and then lock the black piece down it took me about an hour and a half.even with my fat sausage fingers. if you shoot me an e-mail with your phone number i can walk you through it. daddygmac9@yahoo.com good luck
Olympus Stylus... | Answered on Sep 26, 2013
The problem you are describing is a problem with something in the lens assembly of the camera. It seems to have failed and needs to be replaced.
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $83.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Olympus Stylus... | Answered on Dec 02, 2011
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Olympus Stylus... | Answered on Oct 10, 2011
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Olympus Stylus... | Answered on Sep 19, 2011
When you transfer this pics at pc... they are black too? Could be a problem with the LCD screen viewer or CCD Image sensor go to bad. In both cases this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your Olympus service. I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Hope this helps
Olympus Stylus... | Answered on Sep 14, 2011
While the camera stores the date (and a lot more) with every picture, it will not deface your pictures by scribbling a string of numbers across them. Any photo editing/cataloging program should show you this information. Depending on the program and printer, you can print this information on the image, in the margins, or on the back. For example, if you're printing directly from the camera you can turn on DATE under CUSTOM PRINT.
Olympus Stylus... | Answered on Aug 03, 2011
The date and time (and a lot more) are recorded with every picture. Just about all photo viewing/editing programs will show you this data. Depending on the program and printer, you may print the date and/or time on the image, in the margins, or on the back. Refer to the documentation for whatever program you're using to view/print.
Olympus Stylus... | Answered on Jul 01, 2011
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
Olympus Stylus... | Answered on May 29, 2011
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
heatman101
Olympus Stylus... | Answered on Apr 27, 2011
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Olympus Stylus... | Answered on Apr 26, 2011
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
Call 1-800-622-6372, Mon-Friday 8:30AM-7PM Eastern.
Olympus may be able to ship you the screws.
Olympus Stylus... | Answered on Mar 02, 2011
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Olympus Stylus... | Answered on Feb 13, 2011
Hello
Regards
Andrea
Olympus Stylus... | Answered on Feb 09, 2011
Hello
Regards
Andrea
Olympus Stylus... | Answered on Jan 26, 2011
Olympus Stylus 760 Digital Camera Logo
85 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Stylus Olympus
  • Stylus Olympus
Most Popular Question
olympus 760 error d 8234
  • Cameras
