Convert 230v to 115v
SOURCE: switching my hayward pool pump from 230v to 115v
Setting the pump for 115V wont by itself cause the trip. There is either a ground in the circuit or the GFI is bad. You may want an electrician to test any further than this.
SOURCE: Going from 230v to 115v on Super Pump
open back you will see the bars to hook to it should show which is the right side 3wire only for 115
SOURCE: I am trying to find out how to wire the pump?
Thank you for posting your question here on Fixya.com.
It will not matter which line goes to which post. Just put one to L1 and the other to L2. As for which voltage to set the pump for, you set it to match the voltage present on your lines you are connecting.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
SOURCE: The pump comes factory set for 230v. Power to the
CHECK YOUR BREAKER IT MIGHT BE THAT YOU ARE 230V .. IF IT IS A WIDE BREAKER ITS 230 OR IF IT IS A SLIM BREAKER ITS 115V , A VOLT METER IS YOUR BEST FRIEND.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
SOURCE: I just installed Hayward 1.5HP
double the amps, 230 runs cooler (my fav) . 1.5 is 9.6 amps at 230 volt. you will need to set the motor to run on on the lower voltage this is why you are having problems.. also the motor is thermally protected . this why it will run for awhile and shot off .. remember to prime the pump after any pump repair !!!! . jay the pool pump repair guy in longwood florida
