20 Most Recent
Hayward Super Pump 1 1/2 - Hp for In Ground Pools Questions & Answers
I have a Hayward Super
You may have sized the shaft seal wrong or the seal may be installed incorrectly. Make sure you have the correct seal and that the shaft is not wobbling.
Should the motor end of the pump be warm/hot to touch?
The motor should be warm to the touch when operating normally. The pump does use the flowing water to help cool the motor so if it is running but no water is being circulated it can get hot.this is not good for the motor so check pipIng and filters regularly for any obstructions.
GFCI Breaker tripping when turned on
Try running the motor in the dark. You may find it arcs to the chassis of the motor and that is your culprit. Had same thing on a hot tub 10 years ago. The professional techs tried everything for me. i finished the last part at 10pm and turned the motor on and saw the arc then trip the gfci. Good luck
