20 Most Recent AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor / Cen Questions & Answers
How do I go from a 2 speed hayward pump to a
Wire the red and black to the Line 1 connection on the motore, and the blue on the Line 2, Make sure your motor voltage is correct and turn on.
6/1/2023 5:18:15 AM • AO Smith Pool... • Answered on Jun 01, 2023
2answers
Where is the capacitor on
the capacitor is located in the housing that is on the top of the motor.
5/22/2021 8:52:20 PM • AO Smith Pool... • Answered on May 22, 2021
2answers
Need to replace pump Impeller on A.O. Smith
To get to the Impeller you need to remove a series of bolts, or a large clamp, that holds the two halves of the pump together. Once you do that, if their is a diffuser (housing that goes over the impeller), remove it. To remove the impeller, you need to lock the motor shaft. You can do this a couple different ways depending on the motor. There will either be a small cap that grants access to the motor shaft on the back of the motor, or you remove a larger housing that grants access to the wiring and other components in the back of the motor. If it's the small cap, then you can hold the shaft with a wrench. If it's the larger housing, then you can slip a wrench (probably 7/16") under the thermal overload switch and onto the shaft to lock it in place. Now you can unscrew the impeller. Check to see if the impeller has a screw in the center. If so remove this first. It will be reverse thread. The impeller should spin off counter clockwise. If the impeller is very tight, be careful not to damage it. If you don't have an impeller wrench, I strap wrench, or very large locking pliers with a rag around the impeller works well. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
11/22/2018 1:25:47 AM • AO Smith Pool... • Answered on Nov 22, 2018
Which wire goes to which post ? Intermatic T104R
The two wires are interchangeable.
11/12/2017 7:57:32 AM • AO Smith Pool... • Answered on Nov 12, 2017
1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
8/16/2017 1:25:22 AM • AO Smith Pool... • Answered on Aug 16, 2017
0answers
2answers
My motor has black, white, and brown wires coming out of it. I had sketched the connections but left it out in the rain and now don't know how to hook it up.
Are these the wires that come from a power source to the motor? Which are called Line wires. if these are Not Line wires, then they are the motors internal wires, and you could be out of luck? You will need the manufacturers wiring diagram. If they are Line wires, then simply... Get a multimeter, turn power on, and test each wire to ground. This will tell you if and which each wires is line/hot or not.
6/7/2015 1:21:09 PM • AO Smith Pool... • Answered on Jun 07, 2015
2answers
I have ecco tub ,one pump is not runing
try spinning the shaft by hand if it sounds gritty yes
5/14/2015 3:42:31 AM • AO Smith Pool... • Answered on May 14, 2015
How much does pool pump model k48m2n11 cost
What's the make and model.Sorry, but info you provided is of no value.Need specifics of complete pump
5/11/2015 3:11:38 AM • AO Smith Pool... • Answered on May 11, 2015
How do you put boil in hayward sp1515kx pump
Oil? you can't oil a pool pump.
5/11/2015 3:10:52 AM • AO Smith Pool... • Answered on May 11, 2015
AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor  / Cen Logo
Popular Tags
103 questions posted
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
AO Smith Pool & Spa
  • AO Smith Pool & Spa
Most Popular Question
new pool pump motor governor keeps
  • Pool & Spa
