Is there such a thing?
Sony eSupport>Vaio PCV-RZ22G>Manuals,
http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCVRZ22G
I would like you to left-click on -
PCV-RZ Series Hard Disk Drive Replacement Instructions.
Use the Maximize icon to enlarge it to full screen.
Tells you, and shows you how to open your computer case.
Yes;i've thee solution. 1.ignore the hex heads.2.release tabs (2) are located on the back from the front veiw you can slid your hand back there , squeeze in both ,then you can slid the (left) panel back (towards rear of unit) and then off the unit.
the hex heads are for show / decoraration only.from the front of the computer go to rear along the left hind side.find two (2) release tabs,they need too move out-wards towards ,the removable left hand side panel,which once tabs release ; allow it to slide back wards towards to rear of th unit.hope this is clearer..from rear view ,find one upper one lower release tabs press both in towards the outside(right-side) of unit,then pull panel backwards;(towards yourself).
Yes, there are tools called "Allen" wrenches. They come in sets.
I know that, however no, repeat no Allen wrench in my thoroughly extensive collection of Allen wrenches fits into the side panels of the VAIO tower. They are either too small or too large. The question is, does Sony have it's own Allen wrench?
