JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
Anonymous Posted on Apr 26, 2013
Just bought and installed convergence board and green is sweaped to one side in the middle
Level 3:
Top Expert:
  • JVC Master 76,851 Answers
  • Posted on Apr 26, 2013
JVC Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008447
Points
237762
It sounds that the convergence adjustments should be re-touched. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.
2 Related Answers
Anonymous
  • 4402 Answers
  • Posted on Jan 28, 2008
SOURCE: Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Anonymous
  • 1139 Answers
  • Posted on Mar 23, 2009
SOURCE: convergence problem
Did you lock the adjustment into the TV's memory? This step is the most often missed. Please follow the directions on the Users manual or on the service manual on how to set your memory to hold the configuration.
Find the menu item on setting the convergence adjustment into memory (the menu should have an informational screen on this topic)
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
I am seeing doubles of everthing all of a sudden,and i see what seems to be red green and purple please help i think all 3 bulbs are working
When you go to Menu then setup Do you see Convergence? I fMenu is listing convergence ,then wihTV off Press and Hold CH- and Vol- at same time hold untill Tv comes on,it will either reset Factory settings or let you in Service Menu.
If you Do Not see convergence the you have a blowed Fuse FL231 on the dflection Board ,it will be the bottom lefthand side Board and on the right side of FBT flyback Transfomer is 3 Fuses they are 3 in a roll,small brown looking caps,but are Fuses it will be the one in the Middle.
Green tint only on left hand side towards the middle of the screen
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
My screen is concave and the red blue green colors are all 3 dimensioanl
Go to Menu then setup Look for Convergence if you do not see convergence listed,Then you have a blowed fuse on the Deflection board. It is the bottom board on left hand side it will have the FBT flyback Transfomer and on the Right Side of the FBT is 3 fuses right in a roll they will look lijke small brown retrangler Caps BUT are Fuses 0.6amp. It will be the Middle Fuse.
Partstore.com has them.
Heres another thing you can try with TV off Press and hold Vol- and CH- at same time hold untill TV comes on Now look for Auto Convergence.
Image on screen looks concave(middle of screen looks farther away than left or right side.)
Roseannmace,
Your TV is out of convergance. You'll probably noticed that there are red, green, and blue images. You'll need to determine if the problem is in the power supply or the convergance board. Usually, the convergance amps go bad and opens resistors. Do you know how to read a schematic and use a multimeter? You will also need to know how to remove the old parts and solder the new parts into the circuit board.
Ken.
Rca television model #D52w27d does not show convergence on the menu setup on the remote. The television is showing alot of green & red, it is showing double vision. e-mail [email protected]. We...
You have a Blowed fuse on deflection board It will be bottom left hand side board it has FBT flyback Transfomer on it and Right hand side of the FBT is 3 Fuses in a Roll they are small brown looking caps But they are fuses .06amp fuse it will be the one in the Middle FL231.
Panasonic blue convergence problem
need to replace both stk392-110 , one is for vertical and the other for horizontal , if one is bad the otrere one would go bad anytime
Convergence adjustment
HELLO . it sound like you need to replace the convergence board or just the IC'S ON THE BOARD. IT WOULD BE CHEPER THAN THE HOLE BOARD. "GOOD LUCK"
Convergence Problem
sounds more like the convergence amp ICs STK392-040 you can get replacements here that comes with instalation instructions.
http://servicemanuals.vstore.ca/
Green "halo" around the bright white images
I have a Samsung HCM5535W rear projection TV that had pretty much the exact same problem-- a green halo around bright white images. I researched it on the net, and determined the most likely problem was with the convergence STK-ICs, or the convergence board. I bought a replacement board with the STK ICs and installed it, but no luck, the problem persisted. I decided to mess with the manual focus adjustment on the green crt (i was seeing a green halo), and that fixed it. As it turns out, no replacement parts were necessary to fix the problem in the first place. Hope this helps somebody out there.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
