20 Most Recent Toshiba 43HX70 43" Rear Projection Television Questions & Answers
Recycle Projection tubs
The fluid is probably glycerin The lenses are glass The tubes are leaded glass check your local best buy toshiba has a take back program and http://search.earth911.com/?what=Television+Accessories
2/3/2015 3:37:46 AM • Toshiba 43HX70... • Answered on Feb 03, 2015
Due to surge in power,
1. usually when a power surge has occurred and a electric appliance is the victim o f that surge the first thing in the power supply circuit to go is the rectifier diodes or rectifier array and the surrounding filter capacitors. this array regulates the AC coming into the set as a full wave signal.
2. It is wise to refer to a schematic when repairing a rear projection TV. Some components are static sensitive.
3. checking all the component at the input of the start up circuit is first and foremost.
7/7/2011 5:39:23 PM • Toshiba 43HX70... • Answered on Jul 07, 2011
Toshiba 43hx70 power light blinking
You have Bad ICs,they are Big Black ICs and will have PN# on them STK392-110
also check the 3 resistors 1.8ohms
Mats Electronics has ICs 1-800-628-1118
2/17/2011 12:52:40 PM • Toshiba 43HX70... • Answered on Feb 17, 2011
Picture looks like rainbow
You will need to replace the convergence IC or ICs and replace any 2 watt low ohm (under 10 ohms) resistors. Your best repair for this along with instructions is to find this website. wwwTvRepairKits.com. Have your model number handy...everything you need will be included, with there step by step repair. I have used this a couple of times and was successful. Thanks for asking!
2/13/2011 10:18:10 PM • Toshiba 43HX70... • Answered on Feb 13, 2011
2answers
I have sound but no picture>
The t-con board of your television is bad, that is why your television is having sound but no picture.
The t-con board is by the upper middle of the main panel of the television, Have it replaced and your television will be in good condition once again.
Hope this was helpful to you.
Take care and good luck.
1/2/2011 1:26:52 PM • Toshiba 43HX70... • Answered on Jan 02, 2011
Toshiba back projector 43' how do i make the av
Look at what input you plugged the DVD player into. maybe AV1 or AV2
Now on your remote, or on the front of the TV, push input until it stops on the one that your DVD player is plugged into.
8/28/2010 1:35:52 PM • Toshiba 43HX70... • Answered on Aug 28, 2010
TV turns off and power light blinks
Hi
Thanks for using FixYa. Clicking sound can be from a bad capacitor on the power supply board. To start with open the back of the unit and check the power supply board for any blown capacitors. Also check the flyback as it can be some loose wires in the coil. Usually this happens when there is a vibration in the horizontal circuit, the flyback and/or coil can make this noise. Also inspect the fuse if they are working fine and please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Opening the unit is only recommended if you have some electrical expertise. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
6/7/2010 4:40:33 AM • Toshiba 43HX70... • Answered on Jun 07, 2010
Image on screen looks concave(middle of screen
Roseannmace,
Your TV is out of convergance. You'll probably noticed that there are red, green, and blue images. You'll need to determine if the problem is in the power supply or the convergance board. Usually, the convergance amps go bad and opens resistors. Do you know how to read a schematic and use a multimeter? You will also need to know how to remove the old parts and solder the new parts into the circuit board.
Ken.
5/27/2010 3:15:12 AM • Toshiba 43HX70... • Answered on May 27, 2010
Blue Halo - convergence issue with 43Hx70
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
4/18/2010 2:09:44 AM • Toshiba 43HX70... • Answered on Apr 18, 2010
The red convergence on the right half of my screen
I would replace the Convergence IC's. They should be STK-392-110's. It should cure the problem.
They are typically mounted to heavy duty Heat Sinks and located generally on the Video Board. You should replace both of the IC's as a pair. I would also make sure you use Heat Sink Compound on the back of the new IC's when remounting them.
I hope this helps,
Skyassoc
12/27/2009 5:56:24 AM • Toshiba 43HX70... • Answered on Dec 27, 2009
2answers
Convergence problem
sounds like you need to change the convergence chip to me. you can order a kit with instructions from www.tvrepairkits.com for most tv's.
If you plan on doing this you need a good soldering gun and a steady hand.
5/18/2009 12:53:42 AM • Toshiba 43HX70... • Answered on May 18, 2009
I have a red shadow
Its a convergence issue. The convergence IC needs to be replaced.
SOLUTION :
Here is a detailed guide with screen shots that will help you solve the problem.
TUTORIAL 1 : http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
ANOTHER TUTORIAL : http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
4/9/2009 3:35:23 PM • Toshiba 43HX70... • Answered on Apr 09, 2009
Blue halo on bottom 1/3 - Convergence issue with my 43HX70
HELLO SOUND LIKE YOU NEED TO CHANGE YOU IC CHIP'S ON THE CONVERGENCE BOARD.1!1 THERE WILL BE THREE OF THEM .!!! CHANGE ALL OF THEM AND THIS SHOULD FIX YOUR SET. "GOOD LUCK"
11/5/2008 11:28:14 AM • Toshiba 43HX70... • Answered on Nov 05, 2008
Toshiba blinking power light...nothing on screen
HELLO.!!! IT SOUND LIKE YOU HAVE A BAD HORIZANTAL OUTPUT TRANSISTER & FLY BAD FLY BACK TRANFORMER. TRY CHANGING THEY'S .!!! THEN YOU SHOULD HAVE A WORKING SET"GOOD LUCK"
11/5/2008 11:23:09 AM • Toshiba 43HX70... • Answered on Nov 05, 2008
No boot up
hello it sound's like your fly back transformer is bad check the horzantal output transister.and it.!!! change them and your set will work. most likly.!!! "GOOD LUCK"
11/5/2008 11:15:55 AM • Toshiba 43HX70... • Answered on Nov 05, 2008
Convergence problem?
you need to replace both convergence ICs STK392-110 you can get replacement ICs at the following link and they provide free instalation instructions with pictures so you can do the job yourself. Heres the link.
http://servicemanuals.vstore.ca/
9/10/2008 12:47:38 AM • Toshiba 43HX70... • Answered on Sep 10, 2008
Toshiba 43hx70
i dought it, check aroiund the convergence ic's "stk392-xxx"
2/8/2008 7:44:10 PM • Toshiba 43HX70... • Answered on Feb 08, 2008
Toshiba projection tv
there is no pink in resister codes
red or orange i think it's orange
32 X 8 or 5 32000 32K? most are low resistance
3.9 ohms and below.
2/8/2008 6:56:44 PM • Toshiba 43HX70... • Answered on Feb 08, 2008
Toshiba 43HX70 43" Rear Projection Television Logo
25 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
recycle projection tubs
  • Televison & Video
