Biostar M7VIZ Motherboard Logo
Damon Rogers Posted on Aug 04, 2007
Alarms Symptons: Upon power up windows fails to start, "Windows could not start because the following file is missing or corrupt: WINDOWS\system32\config\SYSTEM You can attempt to repair this file by starting Windows Setup using the original Setup CD-ROM. Select "r" at the first screen to start repair" Attempted Resolution1: Restart computer using orig. factory issued cd that came w/computer purchase. Selected "r" at first screen as instructed to begin recovery process. Selected option to restore windows w/out reformatting HD. Results: After process of reinstallation of windows, instructed to restart windows. After computer shuts down for restart a constant repetitive beep at about 5 sec intervals is heard & monitor displays no signal received, computer shuts down but does not power off. After powering off computer manually, upon restart, constant repetitive beep at about 5 sec intervals. Checked monitor by installing on another computer & doing multiple restarts, works fine.
  • Rich Melvin
    Rich Melvin Jun 22, 2013
    Not the solution. It doesn't stay on long enough for the bios to even be seen on the monitor.
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Aug 04, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
836
Points
10
Hello, find the BIOS Beep Codes at http://www.amptron.com/html/bios.beepcodes.html and try to find your problem. It is not a software or Monitor problem. It could be RAM or Video Card failure
I have an evo n610c and it started up with a message that says, "Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair thi
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
1helpful
Following files missing or corrupt: \windows\system32\config\system
Well this means one of important files needed to start Windows is corrupted (it's a registry file).
I'd recommend repairing Windows installation. If you have Windows XP and also the Original Windows CD follow: this guide.
You need to re-install windows as your windows is corrupted.
Not abe to boot up
YOUR WINDOWS FILE IS CORRUPT AND YOUR RECOVERY CD AND BACKUP WHICH IN HIDDEN IN THE SYSTEM IS ALSO CORRUPT . YOU HAVE TO INSTALL WINDOWS AGAIN IF YOU KNOW OTHER WISE CONTACT SERVICE CENTER FOR YOU PC.
1helpful
Maxtor D740X-6L 40 GB drive won't start up.
Put your windows xp disc in the drive and boot up from it, run windows repair or failing that reinstall on the upgrade option to keep your files and programs.
If that fails, you will have to do a full instal.
2answers
How do I...
NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
Keyboard issue
Miscellaneous corruption
Corrupt boot.ini file.
Missing boot.ini file.
Missing or corrupt ntoskrnl.exe file.
Windows NT installed on a partition bigger then 7.8GB
Corrupted hard disk drive or severely corrupted Windows.
Solution:
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
In the setup menu, type R to start the repair.
When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
Select the operating system you wish to fix, and then enter the administrator password.
Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the
error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
Once at the recovery console type chkdsk /r
Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Top Biostar Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
