20 Most Recent Dell OptiPlex GX110 PC Desktop Questions & Answers
2answers
Won't read keyboard
usb or ps2 keyboard ? might need to be enabled in BIOS If you want to use a USB keyboard to access Windows command prompt options, make changes in the BIOS (Basic Input/Output System), or to operate legacy operating systems, you must enable support for the device inside the BIOS. Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Turn on the computer and press the "Delete" key several times as soon as you see the initial boot or company logo screen. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
9/20/2015 8:10:49 AM • Dell OptiPlex... • Answered on Sep 20, 2015
I have created bootable usb disk by following instructions on pendrivelinux.com . But not able to boot in optiplex gx110 window xp pc.Also it is not showing usb drive in boot sequence.
This machine does not support USB boot function. Meaning, you wont be able to do so in this specific machine.
5/2/2014 3:01:21 PM • Dell OptiPlex... • Answered on May 02, 2014
Diskette disk 0 seek failure
It's trying to boot the computer from the floppy diskette drive.
5/1/2014 2:04:46 AM • Dell OptiPlex... • Answered on May 01, 2014
2answers
OptiPlex GX110 PC Desktop: Hello.. I'm having Dell Optiplex machine.When I t...
Generally an indication that the Hard Drive isn't detected
Things to check, go to BIOS F2, reset defaults and reboot, see if the HDD is seen. If it is, the battery on the motherboard is likely dead and needs replacement (Watch battery at Walmart, 3 dollars)
If the HDD doesn't detect after resetting the BIOS, then most likely a Hard Drive failure
1/27/2014 4:59:36 AM • Dell OptiPlex... • Answered on Jan 27, 2014
Data is not sent to the monitor
The first thing to do is to pay attention for "beep" when your press the power button (or the reset button) to turn the computer on or reboot it. The beeps that a PC makes tells you a lot about the state of your computer. I couldn't quote for you the exact beeps to listen for, but your manual for your motherboard may tell you. Different beep pattersn tell you what is wrong with a computer.
I think for many common motherboards it is something like 4 beeps to tell you the graphics card has failed. Don't quote me, but that is at least along the lines of how it works if not the exact number.
If you're getting no display after starting your computer make sure you hear one beep. Then, listen for other activity. If you're computer has a floppy drive, listen for the 'floppy seek'. Otherwise, listen for hard drive activity. If it sounds as though there's activity along those lines but still no signal/display on the monitor perhaps check the cable between your PC and the monitor. Never hurts to just make sure the monitor is turned on of course.
If your monitor is on, and the cables are connected securely I wold restart the computer again and check for the beeps. I would be certain to count them and check the manual. Your graphics card may have failed if you hear abnormal beeps (more than one as one is usually the healthy indicator). If you hear no beeps then the PC is not even getting in as far as testing it's devices and could quite possibly be a motherboard failure.
1/24/2014 2:37:22 AM • Dell OptiPlex... • Answered on Jan 24, 2014
Curser locked up
reinstall windows!
1/8/2014 12:46:38 PM • Dell OptiPlex... • Answered on Jan 08, 2014
What are the bios settings for dell optiplex
F12 then choose Set up
12/27/2013 6:04:01 PM • Dell OptiPlex... • Answered on Dec 27, 2013
Bios password remove
You have to reset your BIOS.1. On the motherboard near the battery you will find a jumper. Put the jumper to cross the pin number 2 and 3. Turn on your PC. Wait 3 seconds. Remove the power cord from PC.After that, put the jumper at the original state, and the bios doesn't has password anymore.2. Or remove the battery, put it back after 60 seconds.
10/2/2013 2:02:14 PM • Dell OptiPlex... • Answered on Oct 02, 2013
0answers
Boot with press f1
to do a format you must boot the pc with the disc in the drive, and set pc to boot from dvd, in boot options, then when it comes to install options press options and format, this will do a wipe/format and you should be ok from then.
1/26/2013 7:53:56 PM • Dell OptiPlex... • Answered on Jan 26, 2013
Can I install windows on my dell optiplex gx110 using flash drive(USB)?
I would say yes, as long as you can get it boot from the USB. Check BIOS. Are installing you Win 95, 98, or XP? I ask because the manual has reference to Y2K.You just want to keep it as a Linux box. Have Fun!
10/6/2012 6:29:59 PM • Dell OptiPlex... • Answered on Oct 06, 2012
2answers
Non display for DELL GX 110PC Desktop
Either your monitor is bad or the video card inside the computer is bad. To isolate the problem try a different monitor on the computer. Borrow a monitor from a neighbor, friend, relative or co-worker. If the borrowed monitor works, then your original monitor is bad. If the Borrowed monitor does not work, then the video card inside your computer is bad.
5/12/2012 10:13:18 PM • Dell OptiPlex... • Answered on May 12, 2012
Non display for Dell Optiplex GX110?
5/12/2012 12:18:27 AM • Dell OptiPlex... • Answered on May 12, 2012
Cd rom detection problem on optiplex gx110
have you checked to see if the cd drive is showing up in MY COMPUTER?if it's not the it's possible that the cd drive needs to be replaced
4/4/2012 3:30:41 PM • Dell OptiPlex... • Answered on Apr 04, 2012
Dell optiplex gx110 will not start
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease
hope this helps you
3/23/2012 6:59:31 PM • Dell OptiPlex... • Answered on Mar 23, 2012
My PC has a orange
An Amber blinking powerbutton indicates a low voltage problem. This can be caused by a defective powersupply or a defective motherboard. Just to make sure that nothing else iscausing the problem, remove any PCI cards like modem, video card, sound card,etc... Remove the memory modules and disconnect cables to CD/DVD drives. Lookat the USB ports to see if any are damaged.
9/24/2011 10:31:48 PM • Dell OptiPlex... • Answered on Sep 24, 2011
Memory address line failure read
Malfunctioning memory module - replace it and try again. If you get a similar result then the defect is in the memory controller from the motherboard. This is unfixable, the motherboard is dead - replace it.
9/5/2011 3:37:27 PM • Dell OptiPlex... • Answered on Sep 05, 2011
Dell OptiPlex GX110 PC Desktop Logo
139 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
OptiPlex Dell
  • OptiPlex Dell
Most Popular Question
curser locked up
  • Computers & Internet
