20 Most Recent Biostar K8M800-M7A Motherboard Questions & Answers
No detection of Western Digital (my passport) portable hard drive
a 2006 relic mobo, the mobo has FIXED hard, chip called Vbus, and current is limited that chip, max. and is shared to say 4 USB ports. so is shared to get more current use external hdd its power pack, 2.5amps up 3.5" no Passport told we can not guess models of external drives, ever and matters huge some old mobo are 100mA limited and most external drives fail. lack of current. and can even wreck the drive is it goes made self booting and spin failling endless (super bad that) ok now the cure. easy buy a USB3 powered HUB that has a 1amp or more power pack bingo works. no OS told ,xp , w7 , vista, what, as settings are not the same most usb ports do no have manual power settings ever. so use hdd that has a power pack, 3.5inchj all do buy a usb powered hub
5/17/2022 2:44:02 PM • Biostar... • Answered on May 17, 2022
I have several biostar k8m800-m7
Your motherboard did not post . When this happens nothing works. Your card is probably good. But before we jump the gun, just make sure that it is not a power supply issue that is preventing startup. Try another known working supply to see if the mo bo works. If not, then it is a cmos issue
9/16/2017 11:25:56 AM • Biostar... • Answered on Sep 16, 2017
My biostar k8m8oo-m7a powers up but has no video
I screen is simply black, it is probably the RAM Remove the RAM, gelty clean it off and reinstall
7/10/2014 4:03:14 AM • Biostar... • Answered on Jul 10, 2014
I lost my msi ms-7312 motherboard drivers cd? can u help me...
http://www.msi.com/product/mb/K9MMV.html#/?div=Driver&os=All
5/21/2014 6:46:14 AM • Biostar... • Answered on May 21, 2014
0answers
Marksman car alarm
Be the first to answer 4/30/2013 5:45:31 AM • Biostar... • Posted on Apr 30, 2013Be the first to answer
IM RUNNING WIN 7
k8m800-m7a support windows 2000/xp try to change your OS
4/5/2013 1:20:04 AM • Biostar... • Answered on Apr 05, 2013
Hello the manual and other stuff can be downloaded here:http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=209#dlTry to renew the power supply.Here is a fault finder guide:http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problemsGood luck
1/23/2013 2:55:16 PM • Biostar... • Answered on Jan 23, 2013
Not functioning
Hello you can download the manual here:http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=209#dlIf all connections is ok the mainboard could be dead.Good luck
1/1/2013 4:41:48 PM • Biostar... • Answered on Jan 01, 2013
I want the vga drivers for dell inspiron n 5050
If you can't get them from Dell, try driverguide dot com. They have a lot of things that are hard to find.
12/15/2012 8:23:04 PM • Biostar... • Answered on Dec 15, 2012
14answers
Dispaly driver vga vr.1.0
what comp[atible video driver for toshiba dynabook satellite 2270 because i dont know what compatible driver for this
11/1/2012 6:44:50 PM • Biostar... • Answered on Nov 01, 2012
How to get 2 mem modules to work together
did you buy them as a working pair or individuallythey are not compatiblehope this helps
7/14/2012 5:59:20 AM • Biostar... • Answered on Jul 14, 2012
Mi serve questa scheda madre
Ciao, qui ? possibile scaricare i driver e un manuale:
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=209
I file scaricati saranno estratte prima dell'installazione
9/12/2011 3:41:53 PM • Biostar... • Answered on Sep 12, 2011
2answers
Dont know the ram that
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • 7/20/2011 7:20:07 AM • Biostar... • Answered on Jul 20, 2011
    When im playing a game
    tyr to reset the bios of motehrboard to set it to factory settings.
    6/30/2011 10:20:15 PM • Biostar... • Answered on Jun 30, 2011
    It start but does not recognise the key board, so
    Please check the cable of your keyboard. or change the port if its USB.
    if same problem borrow one USB keyboard from your friends just to check whether your USB port is working or not.
    if other keyboard is working, your keyboard has gone bad.
    replace your keyboard.
    6/27/2011 5:20:10 PM • Biostar... • Answered on Jun 27, 2011
    Hola tengo una tarjeta k8m800-m7a
    Ultima version
    5/28/2011 8:41:45 AM • Biostar... • Answered on May 28, 2011
    2answers
    I want to attach wd500Gb
    One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
    Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
    the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error make sure that the cd rom is getting enough power test all leads that are attached to the cd drive including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd rom then plug them back in or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if your computer came with a motherboard disc the sound drivers could be on it if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
    Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
    HKEY_LOCAL_MACHINE
    SYSTEM
    CurrentControlSet
    Control
    Class
    {4D36E965-E325-11CE-BFC1-08002BE10318}
    This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
    Upper Filters
    Lower Filters
    Upper Filters.bak
    Lower Filters.bak
    If any of the above keys shown in step 4 are listed, right-click on them and choose Delete After deleting the keys, close the registry editor Reboot your computer Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps
    4/14/2011 6:43:28 AM • Biostar... • Answered on Apr 14, 2011
    PCI Simple Communacation Controller
    Hi, Thanks for using fixya.
    Not to much information here but I'll try and guess.
    Shows up in device manager: Right click on the line with the Yellow ! or ? choose uninstall then reboot the computer and new drivers will be searched for the network card or the modem. If you know the name of the network card and modem do a search for the drivers. If you can't get online search from a friend's computer save the drivers to a flash drive.
    Hope this helps.
    Terry
    If you have any further questions regarding this matter feel free to post a comment or if you are satisfied with my answer, please give it a rating for this is the reason I do this work.
    2/28/2011 2:02:51 AM • Biostar... • Answered on Feb 28, 2011
    Biostar K8M800-M7A Motherboard Logo
    84 questions posted
    Top Biostar Computers & Internet Experts
     Grubhead
    Grubhead
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
    View Most Popular
    • Biostar Computers & Internet
    Most Popular Question
    hola tengo una tarjeta k8m800 m7a
    • Computers & Internet
