20 Most Recent
Biostar M7VIZ Motherboard Questions & Answers
Alarms
Hello, find the BIOS Beep Codes at http://www.amptron.com/html/bios.beepcodes.html
and try to find your problem. It is not a software or Monitor problem.
It could be RAM or Video Card failure
Pdf m7viz motherboard user manual
Biostar Support > M7VIZ motherboard > Main Support page,
http://www.biostar-usa.com/mbdetails.asp?model=M7VIZIn the upper right in a purple header, is Product Info.Click on -> Manual, in the list under it.Go down to the purple heading -> Docs. (Documentation)Under this heading click on the red -> M7VIZmanual.pdfTook 11 seconds before the first page came up.[Note*Hover your mouse at the bottom/middle. The ghosted out navigation guide will appear. Go all the way to the right, and left-click on the Adobe PDF icon. When your mouse is hovering over it ->Show Adobe Reader toolbar - will appear ]No can do?Then tell me what information you wish, in a Comment.I am looking at the Motherboard Manual in PDF file form, right now. I will save it to my computer.(Do not know how to do this? State in a Comment )Regards,joecoolvette
Removing overclock setting
Go into the BIOS and set the computer to the default settings. When the computer starts press the button for "setup" it will be either "F2" or "del" but the button you need to press will be presented on screen.
Sir i lost my motherboard cd which is mercury
first of all, internet does't require lan driver...... it is inbuilt in most of the operating systems..... if your lan is realtek rtl8139ethernet nic, you can download it from http://www.realtek.com/ under quick links in the right
okay???????? pls vote if you like this solution.......
MERCURY PNMCP73V NVIDIA CHIPSET DRIVER NOT
it will be the same as finding a graphics card driver.
nvidia chipset - go to nvidia and use the search for drivers tool they have. it will scan your pc the tell you the driver you need. if you can not scan mobo then listing search is available.
http://www.nvidia.in/Download/index.aspx?lang=en-in
